Community Member
QoS for voice on C2948 CatOS 8.3(2)
Can someone supply a good example of CatOS C2948 config for QoS for voice?
I've been unsuccessful at finding a good config guide on CCO.
Thanks!
1 ACCEPTED SOLUTION
Re: QoS for voice on C2948 CatOS 8.3(2)
Sorry forgott the attachment
Hey,
Try this, maybe this helps.
But beware, 2948 supports only 2 queues and layer 2 cos. So if you have a software that only mark the packets with DSCP (Layer 3)and not the frames with cos values can't really use it.
I decided because of that to use ios switches like 2950, 2960, 3750.
Sebastian
175
