Webcast-Catalyst9k
QoS for Voice on C3560 (and others)
We are looking to build up a very tight trusted bundary for different none Cisco voice-hard/soft-phones on the edge of the LAN.
We are trying to use vendors mac address and used voice/UDP/RTP-ports to classify the "trusted" traffic for EF.
Config could look like:
mac access-list extended vendmac
permit 0080.9f00.0000 0000.00ff.ffff any
access-list 2250 permit udp any range 32514 32515 any range 32560 32570
access-list 2226 permit tcp any any eq 1720
access-list 2226 permit tcp any any range 16340 16800
class-map match-all voice
match access-group name vendmac
match access-group 2250
class-map match-all voice-control
match access-group 2226
class-map match-any best_effort
match access-group 2201
policy-map VoIP
class voice
set dscp ef
class voice-control
set dscp af21
class best_effort
set dscp default
int fa0/1 - 48
service-policy input VoIP
Unfortunately, the service-policy VoIP is not being accepted on the switch ports (fa0/1 -48), since the "class-map match-all voice" contains 2 match statements. (if either of the two match statements is kept as a single entry in the class-map, everything is OK, but then we are loosing the relation VendorMac<>used RTP stream to qualify for real voice traffic!!)
-> Is this a bug ? Works as designed?
-> Any work around??
thank you for any input on this
Re: QoS for Voice on C3560 (and others)
first of all
the udp ACl should be like
permit udp any any range 16384 32767
what i suggest you to do only use the udp ACl
as i mention it above thus, u can remark this udp traffic to EF in the ingres policy on the port
u dont need the mac address
if u look for security issues u cam use port security with max mac can be used on any port to one
good luck
if helpful Rate
Dear Rate,
thx for replying. We are aware off this u cam port security features.
Unfortunatley, we want to correlate vendor mac with the UDP/RTP voice stream, used by the vendor.
but as long it is not support it
and i think u dont need it if u shore the device is connected is a phon
even on cisco documentations and srnds they u se the ACL i sen you to match voice traffic
or u can match the traffic based on its vlan
for example u have all phones i network 10.1.1.0/24
so u mtach all udp traffic from that network
then mark it as EF
any good luck
if helpful Rate
Marwan
178
