Community Member
QOS issue with WAN routers.
Our wan point to point routers are not processing QOS tagging properly.   Below is a sample of my config. For some reason it seems as if qos taggin is not being passed to to the router.   Help, I need to get this going by the end of next week.
Switch1 <---> RouterA <==>RouterB<--->Switch2
Switch1 interface config
interface GigabitEthernet5/48
description DO_WAN_GW_SMS
switchport trunk allowed vlan 1,97,133,916
switchport mode trunk
auto qos voip trust
storm-control broadcast level 2.00
spanning-tree portfast
service-policy output autoqos-voip-policy
RouterA config-----------------------------------------
lass-map match-any Call-Control
match ip dscp af31
match ip dscp cs3
match ip precedence 3
class-map match-any Video
match ip dscp af41
match ip dscp cs4
match ip precedence 4
class-map match-any Voice
match ip dscp ef
match ip precedence 5
class-map match-any Routing
match ip dscp cs6
policy-map RTP-Traffic
class Voice
    priority percent 20
   compress header ip rtp
class Call-Control
    bandwidth percent 5
class Routing
    bandwidth percent 2
class class-default
    fair-queue
     random-detect
policy-map PackClassMark
class Voice
  set ip precedence 5
class Call-Control
  set ip precedence 3
class Routing
  set ip precedence 6
interface Multilink1
ip address 10.0.1.249 255.255.255.252
ip flow egress
ip pim sparse-dense-mode
ppp multilink
ppp multilink group 1
ppp multilink fragment disable
max-reserved-bandwidth 100
service-policy output RTP-Traffic
interface GigabitEthernet0/0.916
encapsulation dot1Q 916
ip address 10.0.1.66 255.255.255.252
service-policy output PackClassMark
RouterB config-----------------------------------------
(policy and class DITO)
ip address 10.0.1.250 255.255.255.252
ppp multilink
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.97
shutdown
interface GigabitEthernet0/0.197
shutdown
interface GigabitEthernet0/0.917
encapsulation dot1Q 917
ip address 10.0.1.70 255.255.255.252
Switch2 config
interface GigabitEthernet7/48
description SMS_WAN_GW
switchport trunk allowed vlan 1,3,97,133,917
switchport block multicast
qos trust cos
auto qos voip trust
storm-control broadcast level 10.00
tx-queue 3
   bandwidth percent 33
   priority high
   shape percent 33
Everyone's tags (3)
379
