qos issues on 3560x - help me to solve issue
Hi all
I have been reading alot of issues around output drops on cisco 3560 switches when qos is enabled.
I just want to provide priority for my voice traffic but without dropping anything else.
the switch is not congested at all, some people say I may be having microbursts which I cannot see, as we have a 1 gig input and a 100 meg output to the wan. the wan interface is where im seeing drops.
I have configured
mls qos
mls qos trust dscp
priority queue out
here is what im getting
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 561
output queues enqueued:
queue:   threshold1   threshold2   threshold3
queue 0:           0           0           0
queue 1:       58460           0           9
queue 2:           4           0           0
queue 3:         12           0           1
output queues dropped:
queue 0:           0           0           0
queue 1:       1088           0           0
queue 2:           0           0           0
queue 3:           0           0           0
Interface Gi0/24 TxQueue Drop Statistics
   Queue 0
     Weight 0 Frames 0
     Weight 1 Frames 0
     Weight 2 Frames 0
   Queue 1
     Weight 0 Frames 16232176
     Weight 1 Frames 0
     Weight 2 Frames 0
   Queue 2
     Weight 0 Frames 0
     Weight 1 Frames 0
     Weight 2 Frames 0
   Queue 3
     Weight 0 Frames 0
     Weight 1 Frames 0
     Weight 2 Frames 475000
   Queue 4
     Weight 0 Frames 0
     Weight 1 Frames 0
     Weight 2 Frames 0
   Queue 5
     Weight 0 Frames 0
     Weight 1 Frames 0
     Weight 2 Frames 0
   Queue 6
     Weight 0 Frames 0
     Weight 1 Frames 0
     Weight 2 Frames 0
   Queue 7
     Weight 0 Frames 0
     Weight 1 Frames 0
     Weight 2 Frames 0
I havent changed any thresholds and buffers
are there any recommended settings for normal none pririty traffic so it doesnt get dropped, auto qos maybe ora good setting for the buffers / thresholds ?
help much needed
cheers
Carl
Super Bronze
Re: qos issues on 3560x - help me to solve issue
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Ah, so your device does register drops!  Is this why you opened a new post?
In any case . . .
One-size often doesn't fit all.  AutoQoS may (v4 does) change queue-set 1 settings.  You might try it and see if it helps, or you might just increasing Q1 T1.  If you try the latter, I suggest you reconfigure queue-set 2 and use it for your WAN interface.  Default value should be 200, so you might try 300 or 400.  You should see a decrease in your drop rate, but all drops might not be eliminated.  Further tuning is possible.  Did you read the reference I provided in your first posting about this issue?
here is my current setup
Queueset: 2
Queue     :       1       2       3       4
buffers   :      25      25      25      25
threshold1:     100     200     100     100
threshold2:     100     200     100     100
reserved  :      50      50      50      50
maximum   :     400     400     400     400
which one do I need to change ?
cheers
Super Bronze
Queueset: 2
Queue     :       1       2       3       4
that is queue 2 threshold 1,
but it looks like my traffic is dropping in queue threshold 1 ?
Super Bronze
Yes it appears that way.
Look carefully at both show command's output - how they number queues.
I dont understand what you are saying ?
it looks like queue 1 threshold 1 is dropping the traffic, you askign me to change queue 2 threshold 1, but the traffic will still be going to queue 1
how come you are saying to adjust queue 2 ?
Super Bronze
Yes, its 0 1 2 3
So are you saying this maps to
1 2 3 4 ?
so queue 1 in the show command is actually 2 when you configure it ?
I just did the command
#mls qos queue-set output 2 threshold 1 100 300 100 100
Drop thresholds exceed the Maximum Threshold - Will use Maximum instead internally
is this correct or ?
Super Bronze
yup
mls qos queue-set output ?
  <1-2>  queue-set id
#mls qos queue-set output 2 threshold ?
  <1-4>  enter queue id in this queue set
Super Bronze
No, you overrode defaults for T2 and max,
try
mls qos queue-set output 2 threshold 2 300 200 50 400
Don't forget to set the WAN interface to queue set 2, too.
is the command you put changing threshold 2 ?
I thought its threshold 1 we need to change ?
Super Bronze
No, believe what I suggested changes T1.  You can confirm with show command after application.
Hi I have done the settings as you said and its made no difference, still getting drops, what should I do ?
queue 0:           0           0           0
queue 1:      111385           0          38
queue 2:          20           0           0
queue 3:          44           0       32441
queue 0:           0           0           0
queue 1:          60           0           0
queue 2:           0           0           0
queue 3:           0           0           1
Super Bronze
Disclaimer
Posting
I did write earlier . . . "You should  see a decrease in your drop rate, but all drops might not be  eliminated."
Did you see a decrease in drop rate?  Your current stats only show 60 drops vs. 111,385 enqueued for Q1T1.  Cisco, I recall, says less than 1% is acceptable.
You have to realize, when you drop from gig rate to 100 Mbps, drops might be unavoidable unless you have infinitely deep queues, and if you did, you'll can obtain infinitely long queuing delays.
If you want to try to decrease the rate even more, try a value of 350 or 400, where 300 was used before.  This might bring the drop rate down a little more, but its likely not to be as dramatic.
Hi There
After some looking into it, im now using the settings below
mls qos queue-set output 2 threshold 2 3100 3100 100 3200
mls qos queue-set output 2 buffers 10 70 10 10
srr-queue bandwidth share 20 60 10 10
queue-set 2
priority-queue out
I can still see a few dropped packets but it the application seems alot better
from the settings I have, would this affect voice at all?
and will this affect the priority queue ?
cheers
Super Bronze
Disclaimer
Posting
queue-set 2
priority-queue out
It (still) could (I see you shifted 10% of buffers from Q2 to Q1, compared to your other posting).  See my response in your other posting, https://supportforums.cisco.com/message/3999090#3999090 why it could.
269
