Community Member
QoS - Matched packets not marked on 4507
I am facing some issues in implementing QoS on a 4507 switch (IOS 12.1).I want to mark traffic sent by all CCTV's, ACS/INTERCOM and BMS devices to respective servers from 54 floors.For that i created access-lists,class-maps and policy maps.Then i applied the policy maps to the respective vlan interfaces.The issue is that, though i can see the hit count of the access-lists incresing and packets matched increasing, the packets MARKED remain at 0.I want these packets to be marked with dscp 16.But it seems it is not happening. I am copying some of the configs. Please advice
Thanks and Regards,
Sonu
class-map match-all TRUST-ACS-INTERCOM
match ip dscp cs2
class-map match-all CATCH-ACS-INTERCOM
match access-group name ACS-INTERCOM-TRAFFIC
class-map match-all TRUST-BMS
match ip dscp cs2
class-map match-all CATCH-BMS
match access-group name BMS-TRAFFIC
class-map match-all CATCH-CCTV
match access-group name CCTV-TRAFFIC
class-map match-all TRUST-CCTV
match ip dscp cs2
policy-map ACT-ACS-INTERCOM
class TRUST-ACS-INTERCOM
trust dscp
policy-map ACT-BMS
class TRUST-BMS
trust dscp
policy-map MARK-CCTV
class CATCH-CCTV
set dscp cs2
policy-map MARK-ACS-INTERCOM
class CATCH-ACS-INTERCOM
set dscp cs2
policy-map MARK-BMS
class CATCH-BMS
set dscp cs2
policy-map ACT-CCTV
class TRUST-CCTV
trust dscp
ip access-list extended ACS-INTERCOM-TRAFFIC
permit ip 172.16.8.0 0.0.7.255 172.16.32.0 0.0.7.255
ip access-list extended BMS-TRAFFIC
permit ip 172.16.88.0 0.0.7.255 172.16.112.0 0.0.7.255
ip access-list extended CCTV-TRAFFIC
permit ip 172.16.48.0 0.0.7.255 172.16.72.0 0.0.7.255
interface Vlan204
no ip address
service-policy input MARK-BMS
service-policy output ACT-BMS
interface Vlan205
no ip address
service-policy input MARK-ACS-INTERCOM
service-policy output ACT-ACS-INTERCOM
interface Vlan206
no ip address
service-policy input MARK-CCTV
service-policy output ACT-CCTV
show policy-map interface vlan 206
Service-policy input: MARK-CCTV
Class-map: CATCH-CCTV (match-all)
5802754 packets
Match: access-group name CCTV-TRAFFIC
QoS Set
ip dscp cs2
Packets marked 0
Class-map: class-default (match-any)
12922590 packets
Match: any
Service-policy output: ACT-CCTV
Class-map: TRUST-CCTV (match-all)
0 packets
Match: ip dscp cs2
12922590 packets
Match: any
1 REPLY
Silver
Re: QoS - Matched packets not marked on 4507
Below is link to Provide with sample config and Reference documents and design guides on implementing QoS on 4507's,
Configuring QoS on the Catalyst 4000 (IOS):
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_1_11/config/qos.htm
409
