QoS on 2960 Lan Base Image
I would like to know, if I could configurate QoS using MLP (using acl to classify the traffic, using class-map and policy-map?
Switch Model : WS-C2960G-48TC-L
flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 20:06 by nachen
Image text-base: 0x00003000, data-base: 0x00D40000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWARE (fc1)
BU205_P1_R1_SW01 uptime is 5 weeks, 2 days, 46 minutes
System image file is "flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin"
cisco WS-C2960G-48TC-L (PowerPC405) processor (revision C0) with 61440K/4088K bytes of memory.
Processor board ID
Last reset from power-on
1 Virtual Ethernet interface
48 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address :
Motherboard assembly number :
Power supply part number :
Motherboard serial number :
Power supply serial number :
Model revision number : C0
Motherboard revision number : A0
Model number : WS-C2960G-48TC-L
System serial number :
Top Assembly Part Number :
Top Assembly Revision Number :
Version ID : V02
CLEI Code Number : COM4A10BRB
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 48 WS-C2960G-48TC-L 12.2(35)SE5 C2960-LANBASE-M
Or I need other IOS ?? For example:
LAN BASE W/O CRYPTO
LAN BASE W/O CRYPTO WITH WEB BASED DEV MGR
LAN BASE
LAN BASE WITH WEB BASED DEV MGR
Re: QoS on 2960 Lan Base Image
Here is your QoS config guide for 2960:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_44_se/configuration/guide/swqos.html
For the features supported, check out the feature navigator:
www.cisco.com/go/fn
Lan Base works
Example:
flash:c2960-lanbase-mz.122-25.SEE2/c2960-lanbase-mz.122-25.SEE2.bin
What about LanLite images?
LanLite IOS does support QoS but only on certain hardware.  For example 2960-24-S does not support QoS.
1903
