Webcast-Catalyst9k
QOS on 2960 WS-C2960S-24PS-L
On this model,  if you use both method:
  • Port based configuration using the mls qos interface based commands   OR
  • MQC based configuration using class-map and policy-map
Which of these is applied to the interface?  I know from other catalyst switches when you configure the port with the service-policy input <policy-map-name> command, it removes the mls qos trust cos command automatically but not on this model.
Config details below:
GigabitEthernet1/0/6
Attached policy-map for Ingress: POL-MAP
trust state: trust cos
trust mode: trust cos
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: cisco-phone
qos mode: port-based
interface GigabitEthernet1/0/6
switchport access vlan 107
 switchport mode access
 switchport nonegotiate
 switchport voice vlan 207
 no logging event link-status
 no logging event power-inline-status
 srr-queue bandwidth share 1 30 35 5
 priority-queue out
mls qos trust device cisco-phone
 mls qos trust cos
 dot1x pae authenticator
 spanning-tree portfast
 spanning-tree bpduguard enable
 service-policy input POL-MAP
Thank you in advance.
Everyone's tags (1)
1 REPLY
Have a doubt the service
Have a doubt the service-policy applied is not going to work as expected? Please help and advice. Thanks
132
