Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
QoS on 3550 - Unexpected drops
I have applied a policy (ingress) on some of my access layer switches in order to classify and mark traffic out at the access edge.  I am also using a policier to mark down traffic in the default class; marking down to CS1 anything that exceeds 3mbps.  The policy has generally been working fine but I received a complaint from one of our security personnel who views surveillance video on his PC via a client that remotes a Video DVR system.  I tracked down the port and noticed that there were drops on the qos statistics and they were incrememting.  I removed the policy and the problem cleared up immediately.  My thinking was the policier would only mark down traffic, not drop anything.  I cleared the mls counters and put the policy back and right away the drops started happening again.  Any suggestions would be appreciated.
class-map match-all EDUMET-CM
match access-group name edumet
class-map match-all POWER-SCHOOL-CM
match access-group name power-school
class-map match-all VOICE-SIGNAL-CM
match access-group name voice-signal
class-map match-all VOICE-BEARER-CM
match access-group name voice-realtime
class-map match-all EX2K7-CM
match access-group name exchange-2007
class-map match-all LWAPP-CM
match access-group name lwapp
policy-map COLOR-PM
class VOICE-BEARER-CM
  set dscp ef
    police 128000 8000 exceed-action drop
class VOICE-SIGNAL-CM
  set dscp cs3
    police 32000 8000 exceed-action drop
class POWER-SCHOOL-CM
  set dscp af31
class EDUMET-CM
  set dscp af21
class LWAPP-CM
  set dscp af21
class EX2K7-CM
  set dscp af11
class class-default
    police 3000000 46875 exceed-action policed-dscp-transmit
int range f0/1-48
service-policy input COLOR-PM
84-IDF2-3550-1#sh mls qos interface f0/46 statistics
FastEthernet0/46
Ingress
  dscp: incoming   no_change  classified policed    dropped (in bytes)
Others: 27435275   26630923   804352     0          231872
Egress
Others: 137755124     n/a       n/a      0          0
FastEthernet0/46
Ingress
Others: 27487141   26664613   822528     0          237824
Egress
Others: 138316355     n/a       n/a      0          0
Re: QoS on 3550 - Unexpected drops
which class would the survelience video traffic fall under ?
You have two classes " VOICE-BEARER-CM &  VOICE-SIGNAL-CM" have drop action.  You did not post your ACL or the video survialence traffic. I suspect that the video suvelaince traffci is matched by one of these classes before it hit the class-default.
Hatim Badr
404
