QOS on 3560
Hi all
I have VLAN based policy as per below.
sh mls qos inte XX stati shows correct marking, however show policy map vlan does not show any traffic clocking up.
I have applied similar strategy on 7600 and can see traffic rate on policy map.
mls qos
access-list 101 permit ip any any
class-map match-all MNGT
match access-group 108
policy-map 671-man
class vlan104
set dscp cs3
interface Vlan2990
service-policy input MVB-MNGT
interface GigabitEthernet0/2
mls qos vlan-based
no cdp enable
1 ACCEPTED SOLUTION
Silver
Re: QOS on 3560
This is a limitation with the hardware on the 3560/3750 platforms. At this time we wont show # of policy-map matches in 'show policy-map interface'.
I dont believe there is a plan to fix this, so the best idea is using the 'show mls qos interface statistics' to make sure the policy is working.
Silver
Re: QOS on 3560
please post more of the config. You have ACL 101, that is not refered to in any displayed class-map.
Also you have class vlan104 but there is no "class-map vlan104" configuration.
There is class-map MNGT configuration, but no policy-map refers to it.
Also, MNGT class-map refers to ACL 108, that is not displayed in config.
Re: QOS on 3560
apologies, I quickly coped and pasted to highlight the method used and I can conform my marking is working as it should.
here is the correct conf:
mls qos
access-list 108 permit ip any any
policy-map MVB-MNGT
class MNGT
set dscp cs6
interface GigabitEthernet0/1
switchport trunk allowed vlan 1520-1526,2990
switchport mode trunk
mls qos vlan-based
interface Vlan2990
Silver
Re: QOS on 3560
371
