08-24-2009 03:44 AM - edited 03-06-2019 07:23 AM
I'm faced with the task of matching and giving priority to some traffic out an interface. This needs to happen in the same box (6500/7600). I have tried the config below, but it doesn't work. Looks like the matching of traffic doesn't work. Sniffing the traffic out the interface reveals that the "set dscp 40" doesn't happen.
I'm am a little lost. Any pointers?
** relevant onfig **
mls qos
# this is default
# mls qos map dscp-cos 40 to 5
access-list 70 permit 10.234.237.131
class-map match-any Test1_QoS
match access-group 70
policy-map Test1_Pol
class Test1_QoS
set dscp 40
interface GigabitEthernet9/12
wrr-queue bandwidth percent 80 19 1
wrr-queue cos-map 2 1 2 5
interface Vlan440
service-policy output Test1_Pol
08-24-2009 07:38 AM
You are missing the command mls qos vlan-based under G9/12. I'm assuming you have switchport access vlan 440 under that interface, right? Additionally, why don't you mark on ingress instead of egress?
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_m2.html#wp1016198
HTH,
__
Edison.
08-24-2009 07:38 AM
I'm not 100% sure, but I think the 6500 support ingress QOS on port and vlan interfaces and egress only on port interfaces.
