Blue
QoS on Ten Gig Card
Hi, all:
What is the command to trust the CoS values marked on the interswitch links (uplinks) on Tengigabit interfaces.
On GigE's it is “mls qos trust cos”
TenGige does not have a similar command….could not find
The closest is “mls qos” (which “enables qos”) (now, does “enable” mean that it “trusts” the markings & treats them accordingly (w/o changing them) ?
1 REPLY
Hall of Fame Super Bronze
Re: QoS on Ten Gig Card
Did you try 'mls qos trust dscp'?
Strange.. I've used trust dscp all the time on TenGig interfaces. Dealing with a 6500 right?
Edison.
164
