QoS priority by precedence trouble on Catalyst Switch Module 3012
We have problem with qos of udp trafic on CBS3012.
There is 2 udp ports. When higher ip precedence of one of them is set, traffic shapes not as should: higher ip precedence level gives lower bitrate and lower precedence gives higher. Tested by iperf on win and freebsd.
Hierarchy looks like this:
virtual mschine with freebsd<---internal port @1G--->cbs3012<---external port @100M--->laptop with win 7
Traffic goes from virtual mashine to laptop.
WS-CBS3012-IBM-I   12.2(55)SE4           CBS31X0-UNIVERSAL-M
Current configuration : 4720 bytes
version 12.2
no service pad
service password-encryption
hostname blade-sw2
boot-start-marker
boot-end-marker
enable secret 5
username admin privilege 15 secret 5
no aaa new-model
system mtu routing 1500
ip routing
ip domain-name stc
ip name-server
mls qos
spanning-tree mode pvst
no spanning-tree etherchannel guard misconfig
no spanning-tree vlan 1-4094
spanning-tree vlan 1 forward-time 10
spanning-tree vlan 1 max-age 10
vlan internal allocation policy ascending
class-map match-any qos-class2
 match access-group name qos-list2
policy-map qos-map
 class qos-class
  set ip precedence 5
 class qos-class2
  set ip precedence 0
interface Port-channel2
 switchport trunk allowed vlan 1,10,11,52,53
 switchport mode trunk
interface FastEthernet0
 ip address
 no ip route-cache cef
 no ip route-cache
 no ip mroute-cache
interface GigabitEthernet0/1
 switchport trunk native vlan 30
 switchport trunk allowed vlan 1,10,11,30,52,53
 shutdown
 spanning-tree portfast trunk
interface GigabitEthernet0/2
 shutdown
interface GigabitEthernet0/3
 shutdown
interface GigabitEthernet0/4
 switchport mode access
 service-policy input qos-map
interface GigabitEthernet0/5
 switchport trunk allowed vlan 1,30
 shutdown
interface GigabitEthernet0/6
 shutdown
interface GigabitEthernet0/7
 shutdown
interface GigabitEthernet0/8
 shutdown
interface GigabitEthernet0/9
 shutdown
interface GigabitEthernet0/10
 shutdown
interface GigabitEthernet0/11
 shutdown
interface GigabitEthernet0/12
 shutdown
interface GigabitEthernet0/13
 shutdown
interface GigabitEthernet0/14
 shutdown
interface GigabitEthernet0/15
 speed 100
interface GigabitEthernet0/16
interface GigabitEthernet0/17
 channel-protocol lacp
interface GigabitEthernet0/18
interface Vlan1
 ip address
interface Vlan30
 ip address
ip default-gateway
ip classless
ip route
ip route
ip route
ip route
ip route
ip route
ip route
ip route
ip route
ip route
ip http server
ip access-list extended qos-list
 permit tcp any any eq 63510
 permit udp any any eq 63510
ip access-list extended qos-list2
 permit tcp any any eq 63511
 permit udp any any eq 63511
ip sla enable reaction-alerts
line con 0
 password 7
 login
line vty 0 4
 exec-timeout 0 0
 password 7
 login local
 history size 50
 transport input all
line vty 5 15
 exec-timeout 0 0
 password 7
 login local
 history size 50
 transport input all
mac address-table static   vlan 1002 interface GigabitEthernet0/19
end
Everyone's tags (1)
24
