QOS scenarios
sarahr202
Level 5
Level 5
Hi everybody
Please consider the following case:
PC1-----Acess link--f1/1--SW1-- Acess link---------F 0/1-R1-acess link-------Sw2-----trunk--------SW3-f1/4--------PC2
All switches are multilayer switches ( 3560)
Pc1 and PC2 are running Cisco Soft phones.
If  we configure SW3 with:
int f1/4
mls qos trust dscp.
1)Does the above command require SW3's  f1/4 be configured as layer 3 port not layer 2?
( My reasoning is since Sw3 has to get to Ip header to process DSCP values, therefore Sw3'f1/4 should be configured  for layer 3 operation.)
2) What if sw3 were not 3560 but layer 2 switch such as old 2900 series. can layer 2 switch be configured with:
mls qos trust dscp.?   Will layer 2 switch be able to interpret dscp values and perform QOS ?
( My understanding is layer 2 switch should not be able to read dscp values )
I  will be posting few more questions on the above scenario.
Thanks and have a nice week.
4 Accepted Solutions
Vivek Ganapathi
Level 4
Level 4
You are slightly confused.
If your port is an access port or a layer 3 port, then you should trust the DSCP markings. The reason you cannot trust cos on an access or layer 3 is, COS bits are present only in 802.1q frame. Whereas, on the trunk links you can trust the COS or DSCP. So, if you trust dscp on trunk link, then dscp-cos mapping table would be used to resolve the cos value. if you trust cos, then cos-dscp table would be used.
Hope this helps.
Vivek
siddhartham
Level 4
Level 4
The below examples describe different scenarioes in Port based QoS configurations
Example 1:
If the port is an access port or Layer 3 port, you need to configure themls qos trust dscp command. You cannot use the mls qos trust cos command because the frame from the access port or Layer 3 port does not  contain dot1q or ISL tag. CoS bits are present in the dot1q or ISL  frame only.
Example 2:If the port is trunk port, you can configure either the mls qos trust cos or mls qos trust dscp
command. The dscp-cos map table is used to calculate the CoS value if  the port is configured to trust DSCP. Similarly, the cos-dscp map table  is used to calculate the DSCP value if the port is configured to trust  CoS.
Example 3:If the port is a dot1q trunk port and the port is configured with the mls qos trust cos
command, native VLAN frames will have CoS and DSCP values as 0. Because  native VLAN frames are untagged and the frame is tagged after it enters  the switch, the switch will set the default CoS value to 0 and the  CoS-to-DSCP table sets the DSCP value to 0.
Siddhartha
Siddhartha
My question is : why does SW3 have to set both COS and DSCP values ? Is  it because SW3 does not know if SW2 is configured  to trust cos or dscp ?
You are right.
Have a look at the below picture and the link, according to that switch creates a QoS label based on DSCP values. I am not familiar with QoS label concept
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_35_se/configuration/guide/swqos.html
https://supportforums.cisco.com/docs/DOC-8093#_Toc191205666
My book says Phone has an internal switch. Does this switch behave the same way when it comes to performing  QOS based on COS?
I am not sure whether the internal switch in the phone can perform QoS or not.
Siddhartha
Siddhartha
Usually both cisco and avaya phones have an option to mark the packets with both COS and DSCP markings
Siddhartha
Siddhartha
7 Replies 7
Vivek Ganapathi
Level 4
Level 4
Hope this helps.
Vivek
siddhartham
Level 4
Level 4
Example 1:
Siddhartha
Siddhartha
Thanks Siddhartha.
PC1-----Acess link--f1/1--SW1-- Acess link--F 0/1-R1-acess link---Sw2--trunk--SW3-f1/4---PC2
int f1/4
mls qos trust dscp.
When Sw3 receives a  ip packet with DSCP value say 24.  Sw3  use mapping DCSP-COS  and then sends the packet out of trunk port with COS value.  The frame traversing the trunk between sw3 and sw2, carries COS  in dot1q tag/isl and DSCP value in ip header.
Some cisco ip phone has one data port and internal port for voip stream.
External  SW----------f1/1 ip phone---Attached PC
For example  if attached Pc generates a   frame and ip phone generates a  a frame carrying voip data, the internal switch must priorities Voip data over pc data by performing QOS before sending them out port( f1/1) connected to an external switch.  Similarly when ip phone receives frames  over its port f1/1 connected to external switch, the internal switch should perform QOS based on COS, putting voip frame in priority queues  for ingress port( f1/1)
Is it correct?
thanks
You are right.
Siddhartha
Siddhartha
Thanks Siddhartham
A cisco ip phone( hardware one) set cos to 5. Does it also set DScp value as well?
thanks and have a nice weekend.
Siddhartha
Siddhartha
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
sarahr202 wrote:
int f1/4
mls qos trust dscp.
Usually not, as switches that "understand" DSCP can examine packet on L2 ports.
"Pure" L2 switches can not examine L3 info, such as DSCP.
"Enhanced" or "intelligent" L2 switches often have the capability to examine some L3 packet info, such as DSCP even when they otherwise only provide L2 switching.
