09-24-2014 05:51 AM - edited 03-07-2019 08:52 PM
09-24-2014 06:22 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As real T1 circuits interfaces are clocked to the T1 transmission rate, there shouldn't be a need to shape.
What are you trying to do, emulate a T1 circuit's performance on something like Ethernet?
09-24-2014 06:22 AM
Disclaimer
Posting
09-24-2014 06:51 AM
I am trying to shape traffic going to the provider via MPLS. Do I need to shape MPLS traffic?
09-24-2014 07:54 AM
Disclaimer
Posting
Maybe, maybe not.
It depends on multiple factors. If your port speed is faster than some CIR and the provider drops or charges extra for overrate traffic, then you'll likely want to shape. Sometimes, if the other side's bandwidth is less than the near side's, you'll want to shape to better manage any congestion.
MPLS vendors often can provide some QoS support. Depending on what they offer, and your needs, you may not need to shape, but perhaps mark your traffic to take advantage of their QoS support.
09-26-2014 05:54 AM
Thanks Joseph. I will look into that. It makes sense to shape ethernet but not a T1. For example if bandwidth is only allocated 50 mb put you can push out 100mb (Fast ethernet interface) then shaping would be necessary.
09-26-2014 07:17 AM
Exactly!
