Community Member
Qos shaping on C4506
Hi, I would like to know if it is possible to specify a virtual interface speed on a gig interface to apply QOS shaping. I have a 4500 port connected at 100 Mbps to a WAN provider device with a 40 Mbps WAN connection. I would like to specify percent shaping for 4 traffic class but i not sure if the shaping will apply for 40 Mbps because my interface is connected at 100 Mbps. Thanks, David
1 REPLY
Hall of Fame Super Bronze
Re: Qos shaping on C4506
Hi David,
I don't have a 4500 handy to reproduce a configuration that I may suggest for you.
However, the documentation should provide guidelines on how to proceed with your task
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/25ewa/configuration/guide/qos.html
HTH,
__
Edison.
192
