Qos Verification on 6500
Is there a command to verify the QOS markings and trust settings on a 6500? I am trying to verify if packets are being marked based on the trust settings. There is no external sniffer. Thanks
Hall of Fame Super Bronze
Re: Qos Verification on 6500
You can capture this information with Netflow enabled globally in the switch and on the interfaces, then with the command show mls ip detail
Router# show mls ip detail
IP Destination IP Source Vlan Xtag L3-protocol Encapsulation
RW-Vlan RW-MACSource RW-MACDestination Bytes Packets Age
Last Seen QoS Police Count Threshold Leak Drop Bucket
Use-Tbl Use-Enble
The TOS information will be shown in the output.
HTH,
__
Edison.
Try this command "show mls qos ip" this will show policy-map/class-map attached and set/trust hits on each class-map. You can also just view an individual interface by using "show mls qos ip interface"
ex. show mls qos ip vlan 50
291
