Webcast-Catalyst9k
qos3outlost SNMP MIB
Anyone know if the qos3outlost has SNMP MIB?  I would like to track the oversubscription on my Catalyst 6509.  Thanks.
Re: qos3outlost SNMP MIB
have you had any luck in finding the MIB ? I'm also searching for it but did not see anything within the object search.
greets
David
David, No, I have not gotten anything helpful. The closest MIB was interface out discards (1.3.6.1.2.1.2.2.1.19). This did not represent the amount of oversubscription we were encountering.  You might have better luck with it.
thanks for your reponds. The ifOutdiscards are due to different issues. Nevertheless if i find something regarding the oversubscription i let you know.
all the best
David
709
