01-09-2009 12:38 PM - edited 03-06-2019 03:21 AM
While out at a clients location adding VLans, I had noticed that all of the ports had Bandwidth 100000Kbit and Delay 1 usec added to them. Is there any benefit to this from other than it being defined in say Vlan1?
Steve
Solved! Go to Solution.
01-09-2009 01:02 PM
Hello Steve,
these parameters have administrative nature and don't reflect the real performances.
They are used by routing protocols like EIGRP and OSPF to calculate the interface cost or metric.
They are used by Modular QoS as a reference for commands that use percentages of total bandwidth instead of an absolute rate.
In a Vlan context you should be fine with default values.
And of course these are attributes of each L3 interface for each SVI Vlan1, Vlan 2 and so on
Hope to help
Giuseppe
01-09-2009 01:02 PM
Hello Steve,
Hope to help
Giuseppe
01-11-2009 08:19 AM
Sorry for the late reply, and thank you.
Just for the sake of argument, is there any overhead in this type of situation if this is not being used as you defined?
I guess I just worry about the networks I work on even though those networks are not mine.
01-11-2009 12:33 PM
Hello Steve,
thanks for your kind remarks
Do you mean someone has modified the default values, or if there are other usage for them ?
Hope to help
Giuseppe
