Question about DHCP Bindings
Hi All,
I'm seeing some strange DHCP bindings on our router.
core2#sh ip dhcp binding
IP address Client-ID/ Lease expiration Type
Hardware address
172.16.75.111 0065 Jul 21 2009 02:54 PM Automatic
172.16.75.112 0100.2608.e469.17 Jul 21 2009 02:06 PM Automatic
172.16.75.113 0021.e9a0.777c Infinite Automatic
DHCP config:
ip dhcp pool Wireless-512b
network 172.16.75.0 255.255.255.0
domain-name netspace.net.au
default-router 172.16.75.1
dns-server 210.15.254.240 210.15.254.241
What I don't understand is:
1/ Why is one DHCP client able to obtain an "Infinite" lease? I haven't set the lease option in the dhcp config and it should default to just 1 day. But there's this one DHCP client that keeps getting an infinite lease.
2/ How can one set the Client-ID/Hardware address to something other than the mac address? In the example we're getting a DHCP request from a Client-ID with 0065 - how is this possible???
Thanks.
Andy
Re: Question about DHCP Bindings
Hi Andy,
To answer for #1, it seems that you'r receiving a request from a BOOTP client, you might wanna check RFC1534 for the expected behavior of Infinite lease for a BOOTP client. As a solution you might wanna let the client use DHCP instead if that's possible or ignore BOOTP request on the router using "ip dhcp bootp ignore"
For #2 - Its Implementation specific, i mean it ideally depends whether the Client has the capability to insert DHCP Option 61 as part of the DHCP Discover/request packets..
cheers
Pinku
Thanks Pinku.
1/ "ip dhcp bootp ignore" is not supported on the 7606, so will just have to live with this infinite lease for now.
2/ you are correct, looks to be implementation specific with the client being able to utilize option 61.
Cheers.
Andy
What code do you have on the 7606 ?
cheers
Pinku
Running Version 12.2(18)SXF11
core2(config)#ip dhcp ?
conflict DHCP address conflict parameters
database Configure DHCP database agents
excluded-address Prevent DHCP from assigning certain addresses
limited-broadcast-address Use all 1's broadcast address
ping Specify ping parameters used by DHCP
pool Configure DHCP address pools
relay DHCP relay agent parameters
route Specify the type of routes for clients on unnumbered interfaces
smart-relay Enable Smart Relay feature
snooping DHCP Snooping
There is the option to use "no ip bootp server".
When I enable this command and clear the DHCP bindings, the client still gets on with an infinite lease. Seems to have no impact.
172.16.75.119 0021.e9a0.777c Infinite Automatic
I don't think so disabling "bootp server" will work. It seems the later 12.2SR codebase has the option for disabling BOOTP request via "ip dhcp bootp ignore" CLI..
cheers
Pinku
Hi Pinku,
We'll live with it for now :)
Thanks for your help.
Cheers.
Andy
2849
