question about inactive frame-relay connection?
hanyawad
i'm configuring a frame relay connection between  two routers, and when i typed sh frame-relay map on both routers i got this output:
Serial0/0 (up): ip 140.1.245.5 dlci 405(0x195,0x6450), static,
              broadcast,
              CISCO, status defined, inactive
Serial0/0 (up): ip 140.1.245.4 dlci 504(0x1F8,0x7C80), static,
              broadcast,
and also i couldn't ping from any router to the other one, here is the configurations of the two router
R4(config-if)#interface Serial0/0
                     ip address 140.1.245.4 255.255.255.0
                     encapsulation frame-relay
                     frame-relay map ip 140.1.245.5 405 broadcast
                     frame-relay interface-dlci 504
                     no frame-relay inverse-arp
R5(config-if)#interface Serial0/0
                    ip address 140.1.245.5 255.255.255.0
                     frame-relay map ip 140.1.245.4 504 broadcast
                     no frame-relay inverse-arp interface Serial0/0
by the way, the other configuration of both routers is just the basic configuration
and also i want to add something else, that router 4 is 2600 series  running IOS version 12.2(8r) and System image file is "flash:c2600-adventerprisek9-mz.124-23.bin"
router 5 is 2600 series  running IOS  Version 12.2(8r)  System image file is "flash:c2600-adventerprisek9-mz.124-12.bin"
so please can you tell me how i can resolve this problem,
thanks
Best Regards
Makar
9 Replies 9
Richard Burts
Makar
Can you tell us how these routers are connected? The configuration seems to suggest that there is a frame relay switch that connects them. I am wondering whether that is the case or whether they are actually connected back to back. If you can clarify the connectivity we may be able to give you better answers.
Rick
Rick
cadet alain
is this a back to back Frame-relay config ?
Then do this:
                     no keepalive
                     no frame-relay interface-dlci 504
                     no keepalive
                     no frame-relay map ip 140.1.245.4 504 broadcast
                     frame-relay map ip 140.1.245.4 405 broadcast
Don't forget to no shut the interfaces.
Regards.
Alain
hanyawad
thanks for your reply,
when i tried the config of Alain and type the command sh fame-relay map i got this output on both routers:
R4#sh frame-relay map
              broadcast,
              CISCO
R5#sh frame-relay map
Serial0/0 (up): ip 140.1.245.4 dlci 405(0x195,0x6450), static,
              broadcast,
              CISCO
and also i found the interface is up and the protocol is up on both routers but i still coudn't ping from both to the other one
Makar
Are you connected to a Frame-Relay switch?
Can you post output from sh frame-relay PVC | in STATUS
Regards.
Alain
DLCI = 405, DLCI USAGE = LOCAL, PVC STATUS = STATIC, INTERFACE = Serial0/0
Makar
you didn't answer if you were using a Frame-Relay switch ?
Regards.
Alain
sorry i forgot, this is a frame-relay switch
Best Regards
Labib
If you're configuring back-to-back frame relay you don't need to go through a frame relay switch. The whole point behind back-to-back is to configure a frame relay connection without a frame relay switch. This is why you use the 'no keepalive' command, because otherwise the routers would expect to hear keepalives from the frame relay switch via LMI. Also, as Cadet put in his configuration to you, you will need to use the same DLCI on each side of the back-to-back frame relay connection, because there is no switch to inform it on which different DLCI it should sent it out on.
then put the keepalive command under each interface and configure appropriate frame map command with correct dlci and then post output of :
sh frame lmi
sh frame map
sh frame pvc | i STATUS
Regards.
Alain
