01-11-2010 07:13 AM - edited 03-06-2019 09:14 AM
Dear Mister
I have a 4500 chassis, with two supervisors.
The active supervisor send the next messages:
%IPC-5-REGPORTFAIL: Registering Control Port Id=0x2010003 timeout=0x6
-Traceback= 1022E55C 105DE3A8 105DE42C 1030F26C 10305C08
When we try to put command by console, was impossible. The second supervisor can´t take the control. The equipoment stay "stuck".
By that reason, i have some questions:
- IPC ¿What is it?
- The messages, information in Cisco web I didn´nt find. In your experience is a hardware problem?? or software problem? I must to open a TAC Case.
Best Regards
01-11-2010 10:51 AM
Hello Rodrigo,
IPC generally means inter process comunication, here could mean inter processors communication meaning the two supervisors.
you may have an hardware failure or you may be hitting a SW bug.
May you post a sh module to see the type of supervisors and the IOS image running?
Hope to help
Giuseppe
01-11-2010 11:15 AM
Dear Mister
I attach the "show module":
CORE_CL_EC#show module
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ JAE1037B5WL
2 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ JAE1037B5WX
3 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAB084303K8
4 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAE0922E20A
5 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAE1037B7PH
6 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAE1036AMCR
7 48 10/100/1000BaseT (RJ45)V, Cisco/IEEE WS-X4548-GB-RJ45V JAE1037B344
M MAC addresses Hw Fw Sw Status
1 0018.ba78.3f80 to 0018.ba78.3f81 4.2 12.2(31r)SG2 12.2(25)EWA6, Ok
2 0018.ba78.3f82 to 0018.ba78.3f83 4.2 12.2(31r)SG2 12.2(25)EWA6 Ok
3 0012.43ce.bee0 to 0012.43ce.bf0f 2.1 Ok
4 0014.693c.e240 to 0014.693c.e26f 2.3 Ok
5 0019.2f99.9d90 to 0019.2f99.9dbf 3.1 Ok
6 0018.baff.e300 to 0018.baff.e32f 3.1 Ok
7 0019.2f8f.c2b0 to 0019.2f8f.c2df 3.1 Ok
Mod Redundancy role Redundancy mode Redundancy status
1 Standby Supervisor SSO Standby hot
2 Active Supervisor SSO Active
Can a lot of traffic in a lot of ports be the reason for this.
We configure a Cacti Server, and at the moment of this problem, we have a lot of traffic (undetermined at this time), and the equipment show the next message by console:
%% Low on memory; try again later
Thank you very much.
Best Regards
01-12-2010 12:22 AM
Hello Rodrigo,
this clearly means the device has not enough memory to handle a VTY session.
This is not related to traffic volume but it is likely caused by memory leakage that is a process that is not releasing memory.
High traffic volume can cause high cpu usage not high memory usage.
It is wise to think of using another IOS image, you need to load it on supervisors and then you can restart the standby first.
if I'm not wrong you are using 12.2(25)EW6 you can think of installing a newer one.
short in memory should be likely caused by a SW bug.
Hope to help
Giuseppe
05-30-2012 10:44 AM
Rodrigo, did you get this fixed? I have a 3750G stack that is giving me the same error. We're running 12.2(25)SEE3 code.
06-04-2012 01:54 PM
I have the same problem right now too with 12.2(25) SEE2 on a 3750G Stack after a power problem.
I'm very interested in a explanation..
regards,
Sebastian
