Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Question about Line Cards
I have several 4510E+R switches with the following modules:
Mod Ports Card Type                                                      Model
 1    48  10/100/1000BaseT Premium POE E Series  WS-X4748-RJ45V+E
 2    48  10/100/1000BaseT Premium POE E Series  WS-X4748-RJ45V+E
 3    48  10/100/1000BaseT UPOE E Series               WS-X4748-UPOE+E
 4    48  10/100/1000BaseT UPOE E Series               WS-X4748-UPOE+E
 5     4  Sup 7-E 10GE (SFP+), 1000BaseX (SFP)     WS-X45-SUP7-E
 7    48  10/100/1000BaseT UPOE E Series               WS-X4748-UPOE+E
 8    48  10/100/1000BaseT Premium POE E Series  WS-X4748-RJ45V+E
10    48  10/100BaseTX (RJ45)                                  WS-X4148-RJ
As you can see, the WS-X4148-RJ is an older line card.  Our other 4510s have 2 of these same older line cards installed and are used for the wired side of our Guest network.  Are there any potential negative results of using these older line cards in these chassis?  The reason we do this is so that we have less switches to manage on our network and don't have to worry about purchasing additional equipment to accommodate our wired guests.
Thanks!
Super Bronze
DisclaimerThe Author of this
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I'm not aware of any major adverse impact.
The "original" 4500 cards were limited to 6 Gbps per slot, but that's fine for a 48 FE port card.
You can see on the link below
You can see on the link below the bdw per slot, but other than inter-linecard communication limitation you should not have much problem.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/catalyst-4500-series-line-cards/product_data_sheet0900aecd802109ea.html
78
