11-06-2006 01:09 AM - edited 03-05-2019 12:37 PM
topology
switch1-switch2-switch3
first case:
3 switch in same region
switch 1 is root bridge of instance 0,1,2
set switch 1 max-hop of 1
in switch 3:
the port is blocked in instance 0
but forwarding in instance 1 and 2
case2
topology as first
switch 1 is root of instance 0
switch 3 is root of instance 1,2
set switch 3 max-hop 1
in stwich 1:
the port is blocked in instance 1 and 2
so if case2's result is correct, why the port is forwarding in instance 1 and 2 in case 1?
Solved! Go to Solution.
11-09-2006 09:40 AM
Sorry for the late answer. You can file a bug for that. I hoped that the dispute mechanism could have prevented opening the port on the other switch, but it does not happen because they have different CIST Regional Root (aka IST Master).
Actually, I can have someone within Cisco filing a bug on this. If you exceed the max hop within a region, you may end up with a permanent bridging loop because of this (I guess that's what you were testing).
Francois
11-06-2006 02:01 PM
Hi!
That's an interesting test. The asymetric behavior looks like a bug to me. It is likely that as soon as the CST information is considered aged, the MSTI information is not processed on switch 3 (case 1), which is incorrect.
In case 1, assuming that you are running the latest software, could you let me know the state of instance 1 and 2 on the port of switch 2 leading to switch 3?
Thanks and regards,
Francois
11-06-2006 05:59 PM
hi,Francois
thanks
yes they latest version
cisco1,3 is 3550 -12.2(25)SEE2
cisco2 is 3750 -12.2(25)SEE2
cisco 2 status. all forwarding
Switch(config)#do show sp m
##### MST0 vlans mapped: 1-9,11-19,21-4094
Bridge address 0012.43f8.c880 priority 32768 (32768 sysid 0)
Root address 000b.46c8.2180 priority 32768 (32768 sysid 0)
port Gi1/0/1 path cost 0
Regional Root address 000b.46c8.2180 priority 32768 (32768 sysid 0)
internal cost 200000 rem hops 0
Operational hello time 2 , forward delay 15, max age 20, txholdcount 6
Configured hello time 2 , forward delay 15, max age 20, max hops 20
Interface Role Sts Cost Prio.Nbr Type
Gi1/0/1 Root FWD 200000 128.1 P2p
Gi1/0/2 Desg FWD 200000 128.2 P2p
##### MST1 vlans mapped: 10
Bridge address 0012.43f8.c880 priority 32769 (32768 sysid 1)
Root address 000b.46c8.2180 priority 32769 (32768 sysid 1)
port Gi1/0/1 cost 200000 rem hops 0
##### MST2 vlans mapped: 20
Bridge address 0012.43f8.c880 priority 32770 (32768 sysid 2)
Root address 000b.46c8.2180 priority 32770 (32768 sysid 2)
cisco3 status
Switch# sho spanning-tree mst
Bridge address 000e.83e7.eb00 priority 32768 (32768 sysid 0)
Root this switch for the CIST
Fa0/5 Desg BLK 200000 128.5 P2p
Fa0/15 Desg FWD 200000 128.15 P2p
Bridge address 000e.83e7.eb00 priority 32769 (32768 sysid 1)
Root this switch for MST1
Fa0/5 Desg FWD 200000 128.5 P2p
Bridge address 000e.83e7.eb00 priority 32770 (32768 sysid 2)
Root this switch for MST2
11-09-2006 09:40 AM
Francois
11-09-2006 06:56 PM
get it
thanks
