Question about NX-OS HSRP
devinliu1991
Hi, all
    We had 3 N3K-3048 arrived recently with NX-OS version uk9.6.0.2.U1.2, and we built a simple network with topology below:
    3 N3K join the same HSRP group with N3K-1 in active state, N3K-2 in standby state and N3K-3 in listen.
    N3K-1 and N3K-2 have a default route to outside network above, but N3K-3 doesn't. So if N3K-3 deals the IP packets from PCs in layer 3, the network would be blocked.
    Now our PC could not visit the outside network, and the HSRP states of the 3 deives have been checked and are OK(N3K-1 active,N3K-2 standby,N3K-3 listen). And also the MAC address PC uses to visit outside network is the HSRP virtual MAC.
    When I designate the real VLAN 11 IP address of N3K-1 to be the default gateway instead of the virtual IP address in HSRP group, the outside network becomes available for our PC.
    Is this a bug of the NX-OS version, or a feature, or limitation?
13 Replies 13
devinliu1991
Added,
      We had also built a similar network with 3 3560X, and it just worked properly. So what makes the listen state N3K-3 dealing with the virtual MAC address?
A couple of questions:
What happens if you make N3K-3 the active router?
What happens if you use N3K-3 as a layer-2 device (no HSRP)?
Since N3K-3 doesn't have a default route to the outside network, the packet that forwarded to N3K-3 would be dropped.
If N3K-3 becomes a layer-2 device, packet could travel through it to N3K-1 or N3K-2 and the network will work properly.
But in our network, N3K-3 should be the default gateway in some cases to reach the internal network.
What I really can not understand is that, since the N3K-1 is the active router owned the VMAC, why N3K-3 deals with the the frame with the VMAC as the destination MAC address.
THX
Can you post relevant configs from all 3 switches?
N3K-1:
inter vlan 11
ip add 10.10.11.252 255.255.255.0
hsrp 11
ip 10.10.11.254
priority 150
preempt
N3K-2:
inter vlan 11
ip add 10.10.11.253 255.255.255.0
hsrp 11
ip 10.10.11.254
priority 120
preempt
N3K-3:
inter vlan 11
ip add 10.10.11.251 255.255.255.0
hsrp 11
ip 10.10.11.254
Also the switchport mode and trunk etherchannel state are checked, one uplink on N3K-3 is blocked because of the STP, all normal.
Hallo,
I suppose this behavior is by design.
In a vPC-setup the two nexus are running in an active-standby setup from a control plane perspective only. In fact even the HSRP standby router is aware of the VMAC and whenever it receives a frame addressed for this VMAC it routes the packet to the destination no matter the HSRP state. Thus from a dataplane perspective Nexus switches always run active-active.
While there is no vPC config present here, I assume the same rules apply in your case.
Thanks for your reply,
I had assumed the same before I had another scenario yesterday.
In this case, N3K-1 keeps on to be the active device of VLAN 11 and I have also created a new VLAN 101 on N3K-1 with IP address 10.10.101.1/24.
Since N3K-2 which is in standby state doesn't has the route to 10.10.101.0/24, the packet with VLAN 11 VMAC to be the destination would be dropped if N3K-2 handled it.
But in my test, PC had got ICMP replies from N3K-1 which means that the packet had got through the HSRP standby device in layer-2.
Hm that's queer. Would you mind showing us the output from N3k-2 for
show ip route 10.10.101.1
show ip route 0.0.0.0
show hsrp interface vlan 11
show mac address-table vlan 11  | inc VMAC
show mac address-table vlan 101
and on N3k-1
show hsrp interface vlan 101
on N3K-2
N3K-2# show ip route 10.10.101.1
IP Route Table for VRF "default"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
Route not found
N3K-2# show ip route 0.0.0.0
0.0.0.0/0, ubest/mbest: 1/0
    *via 10.129.4.1, [1/0], 3d07h, static
N3K-2#show hsrp interface vlan 11
Vlan11 - Group 11 (HSRP-V1) (IPv4)
  Local state is Standby, priority 120 (Cfged 120), may preempt
    Forwarding threshold(for vPC), lower: 1 upper: 120
  Hellotime 3 sec, holdtime 10 sec
  Next hello sent in 2.123000 sec(s)
  Virtual IP address is 10.10.11.254 (Cfged)
  Active router is 10.10.11.252, priority 150 expires in 0.173000 sec(s)
  Standby router is local
  Authentication text "cisco"
  Virtual mac address is 0000.0c07.ac0b (Default MAC)
  3 state changes, last state change 3d07h
  IP redundancy name is hsrp-Vlan11-11 (default)
N3K-2# show mac address-table vlan 11 | include 0000.0c07.ac0b
* 11       0000.0c07.ac0b    dynamic   610        F    F  Po1
no mac information for VLAN 101 on N3K-2
on N3K-1
N3K-1# show hsrp interface vlan 11
Vlan11 - Group 11(HSRP-V1) (IPv4)
  Local state is Active, priority 150 (Cfged 150), may preempt
    Forwarding threshold(for vPC), lower: 1 upper: 150
  Next hello sent in 1.705000 sec(s)
  Active router is local
  Standby router is 10.10.11.253 , priority 120 expires in 2.865000 sec(s)
  1 state changes, last state change 3d07h
no mac information for vlan 11 about VMAC
N3K-1# show hsrp brief
                     P indicates configured to preempt.
Interface   Grp Prio P State    Active addr      Standby addr     Group addr
Vlan11      11  150  P Active   local            10.10.11.253    10.10.11.254
  (conf)
Just to be clear we are talking here about your second scenario, right?
From the output we see N3K-2 has a default route. Would it be possible that your ping from pc to VLAN 101 reached its destination via default route 10.129.4.1?
What a pitty, i was hoping to see a "G" in front of the *.
on N3K-1
Er no, I don't think this is possible. There needs to be a static entry belonging to SUP or something like that. Could you confirm this output?
Yes we are talking about the second scenario, for security concern I had changed the IP address, hope you could understand.
VLAN 101 was created on N3K-1 for testing, and the device 10.129.4.1 doesn't have the route to reach 10.10.101.0/24. Only N3K-1 knows about it. So I think in the second scenario, when two N3Ks forms a group, the standby device doesn't handle the VMAC.
I have checked again, and the flag is *.
on N3K-1
I used the "show mac address-table" command to check out again, and I could only see dynamic entries.
And I have also found a relevant bug, but is for N5K, and the condition is hsrp not working.
more details https://tools.cisco.com/bugsearch/bug/CSCts46891
I just think that the condition I had met is also a bug, because when I have the same topology, similar ip addresses, but change the devices to 3560-X, everything works well.
