Question of Cat6513 upgrade
Last week we upgraded Image of Cat6513 from 12.2(18)SXF3 to the latest 12.2(18)SXF16.Everyhing was fine. But when I tried to show module, I found the version of Sup 720 and two ethernet cards became 12.2(18)SXF1 from 12.2(18)SXF3.Is this normal behavior?
I suspect the version (Sup720 is 8.1(3))of hardware did not support the latest version. Is it correct?
If I keep them. did it cause any issues?
Thanks a lot for your help!
Hall of Fame Super Bronze
Re: Question of Cat6513 upgrade
The last number is being truncated. It's a normal behavior due to the field length on that column.
The ethernet modules will use whatever IOS is running on the Supervisor, they don't need a separate IOS installation.
HTH,
__
Edison.
thanks for your help!
104
