Community Member
question on Nexus 7000s
                 Hi all,
Please help with the following question : what is the equivalent command with "show ip int brief" on Nexus 7K ? this N7K command does not give me all interfaces which I need to know which interface is up and which one is down. Thanks for all help.
1 ACCEPTED SOLUTION
Community Member
Show ip int brief does work on NXOS giving you routed interface IPs and status, however you may be looking for the 'show int status' command which will list all interfaces along with name/status/vlan/duplex/etc.
Community Member
Community Member
Bingo, the correct answer is : "show interface status" is what I'm looking for. Thanks a lot, Gneltnor.
162
