Question on secondary ip address
Scott Fella
On one of my clients site router, they have a secondary ip address configured:
interface Ethernet0/0
ip address 10.2.0.1 255.255.255.0 secondary
ip address 10.2.1.1 255.255.255.0
The switch that connects to E0/0 has an ip address of 10.2.0.2. The switch that connects to E0/0 has these interfaces:
interface Vlan1
ip address 10.2.0.2 255.255.255.0
no ip route-cache
interface Vlan60
ip address 10.2.60.1 255.255.255.0
Now vlan 60 isn't pingable from the router since this L3 switch doesn't have ip routing enabled. If I enable ip routing on this switch, I can't ping 10.2.0.2 anymore from the router.
Should I just delete the secondary interface 10.2.0.1 on the router or should I change the ip address of vlan 1 on the switch from 10.2.0.2 to 10.2.1.2?
What are my options.
Thanks!
-Scott
From the router, you need a route to 10.2.60.0/24 by using 10.2.0.2 as the gateway.
It's not a directly connected network so you need to tell the router how to get there.
It's much easier if you enable a routing protocol between these devices.
HTH,
__
Edison.
Please rate helpful posts
Edison Ortiz
Try an extended ping:
R1#ping
Protocol [ip]:
Target IP address: 10.2.0.2
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 10.2.0.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 10.2.0.2, timeout is 2 seconds:
Packet sent with a source address of 10.2.0.1
HTH,
__
Edison.
That works, but i can't ping vlan 60 from the router or a switch that is trunked to that switch.
Router_Elm#ping
Protocol [ip]:
Repeat count [5]:
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/1/4 ms
Router_Elm#ping 10.2.0.2
Success rate is 0 percent (0/5)
switch-elm-idf-a#ping 10.2.60.1
Sending 5, 100-byte ICMP Echos to 10.2.60.1, timeout is 2 seconds:
-Scott
HTH,
__
Edison.
Edison,
Thanks alot.... I enalbed the routing protocol on the router and also had to create a static route to 10.2.0.1 on the switch.
Gateway of last resort is 10.2.0.1 to network 0.0.0.0
10.0.0.0/24 is subnetted, 5 subnets
C 10.2.0.0 is directly connected, Vlan1
C 10.2.60.0 is directly connected, Vlan60
C 10.2.70.0 is directly connected, Vlan70
C 10.2.90.0 is directly connected, Vlan90
C 10.2.80.0 is directly connected, Vlan80
S* 0.0.0.0/0 [1/0] via 10.2.0.1
-Scott
