question on VLAN's
Folks,
What really is the desicion maker to find out what number of VLAN's will be supported on a Cisco switch?
I think during the CCNA course I read that enabling vtp mode transparent supports upto 4096 VLAN's. Some place I read that MST can support more VLAN's.
How can we, on the switch, find out the number of VLAN's we can configure on a particular platform?
Nik
question on VLAN's
Hi Nik,
Enter global config mode and type 'vlan ?' :
(config)#vlan ?
  WORD        ISL VLAN IDs 1-4094
  access-map  Create vlan access-map or enter vlan access-map command mode
  dot1q       dot1q parameters
  filter      Apply a VLAN Map
  group       Create a vlan group
  internal    internal VLAN
cheers,
Seb.
question on VLAN's
Hello Seb,
I respectfully disagree.
The allowed range of VLANs, and the maximum number of concurrently created VLANs are idependent. All common Catalyst platforms support full range of VLAN IDs, i.e. 1 to 4094 inclusive. However, the number of concurrently existing VLANs differs based on the platform.
Fortunately, there is a simple way of finding out the maximum number of supported VLANs - using the show vtp status command.
On an 2950T:
Sw2950# show vtp status
VTP Version                     : 2
Configuration Revision          : 81
Maximum VLANs supported locally : 250
Number of existing VLANs        : 36
On an 2960:
Sw2960# show vtp status
VTP Version                     : running VTP2
Maximum VLANs supported locally : 255
On an 3560:
Sw3560# show vtp status
Maximum VLANs supported locally : 1005
The relation of the maximum number of locally supported VLANs to the STP version is a different story. With Cisco's Per-VLAN (Rapid) STP, there is a separate instance of (R)STP running for each created VLAN. There is a software and a hardware limit on how many STP instances can be run on a single device. Usually, this limit is 128 STP instances (older 2950 switches supported around 64 STP instances). This means in turn that if you have more than 128 VLANs, only the first 128 VLANs will be running STP. All remaining VLANs will not be protected by STP, so if there is a physical loop in the network, there will also be a switching loop in all the remaining VLANs. So this effectively limits you in the number of VLANs you can use (not how many you can create).
Because MST runs in instances that are independent of VLANs, and the VLANs are simply mapped onto these instances, you can have 4094 VLANs mapped onto just a handful of instances - perhaps 3, 4... tens at most. Here, MST is not the "bottleneck" because the number of MST instances you run is independent of the number of VLANs, and can be orders of magnitudes lower - you can have thousands of VLANs, yet just a pair of MST instances. That is why using MST allows you to use more VLANs.
Best regards,
Peter
question on VLAN's
Thanks Peter,
So vtp mode(client, transparent) does not affect the number of VLAN's we can configure. I read something like that in the CCNA books.
Can any command display number of STP instances that the hardware supports?
Even in MST, I can simply club all the VLAN's into a single instance, correct? This would be a bad design but this is permitted.
Nikhil Kulkarni.
question on VLAN's
Hello Nikhil,
Well, to be honest, VTP mode and version pose an additional limit on the range of VLAN IDs you can create (and indirectly, on the number of concurrently existing VLANs as well, logically). If you are running VTPv1 or VTPv2 in server or client mode, these VTP versions support only normal-range VLANs 1-1005. If you want to use extended-range VLANs 1006-4094, you either have to go to VTP transparent mode, or use VTPv3 that supports the full range of VLAN IDs.
Honestly, I do not recall seeing such command.
Yes, it is perfectly permitted. In fact, if you do not change VLAN-to-instance mappings, all VLANs are in the instance 0. Whether that is a bad design is a matter of debate - if you do not need multiple spanning-trees, why run multiple instances?
Best regards,
Peter
Super Bronze
Re: question on VLAN's
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
As also noted by Peter, having all your VLANs contained within a single MST instance isn't necessarily a bad design.  Multiple MST instances are often used to allow L2 load balancing, of multiple VLANs, across multiple L2 physical paths, without having to manage each VLAN's L2 topology individually.
175
