Question RE: Cisco Catalyst 3560-E Default Gateway
Greetings,
Thank you all for taking the time to read this. I am configuring a set of Cisco 3560-E Catalyst switches for a client. During the express setup configuration it has you type the router's ip address into the web browser. The default "10.0.0.1" gateway isn't assigned to my switches. My switches actually have an ip of "10.0.2.1".
My question is whether or not this is a normal occurance. If it is, is there any documentation online I can find to verify this? I've done a lot of google searches and I can't seem to find anything on my own and that's why I turn to you, community.
Thank you once again in advance for your time spent reading this and I look forward / anticipate your response(s).
Cheers,
Mdaly
Bronze
I'm really not a fan of using the express setup.  It makes a lot of assumptions.
If you're able to console into the switch and do a setup via the command line (CLI) then I'd highly recommend that.
Feel free to post any questions about properly configuring via the CLI.
Ven
Ven Taylor
Ven,
Thank you for the swift response! The actual configuration isn't what's vexxing me. Before I send this to my client I was hoping to just confirm if anyone else had encountered the switch having a default gateway of "10.0.2.1".
If so, I was hoping to confirm that this is a normal occurance.
Thanks!
Cheers,
Mdaly
Any insight anyone?
Bronze
Actually, no.  I've never seen that before either.  This doesn't sound like a brand new switch.
Write erase & reload should make it go away.
Ven
Ven Taylor
Hall of Fame Super Silver
Mdaly
Whether 10.0.2.1 is normal (or correct) depends on what was specified for the addressing used in the switch. Since you did not tell us what addressing was used in the switch we are at a disadvantage in trying to tell you whether it is normal. Can you give us more information about what was specified for addressing on the switch?
Rick
Hi Michael,
Is this switch a brand new one or a used one? If its a brand new one then it should only ask you to fill in the default GW field and not suggest any ip address to you. As you might be aware some other vendors use default GW for their low end boxes in the RFC 1918 range given that the LAN range will be one of them anyway.
But to answer your question, I haven't come across any cisco box by default showing up a default GW. Will see if others have seen what you are seeing
Kishore
831
