Question regarding designated port in STP
chandra_rc16
Level 4
Level 4
Can someone please let me know how can i change the designated port to Fa0/2 on switch2 instead of Fa0/2 on switch1 ? Without changing the priority on Switch3. Since switch3 is the ROOT switch.
Chandu
Regards, Chandu
5 Accepted Solutions
hi,
issue in global config the spanning-tree vlan x root secondary on Switch2.
So the assumption in my first post was right, you want to change the DP of the segment between Switch1 and Switch2.
Generally, the port with the better BPDU will be elected as the DP and the non-designated port will result in blocking state.
As you most probably know, in order to build a loop-free spanning-tree, this decision sequence is processed:
  • Lowest Bridge-ID (becomes root bridge; already done)
  • Lowest Cost to Root-Bridge
  • Lowest Sender-ID
  • Lowest Port-ID (doesn't play a role in this topology)
Both BPDUs (Switch1 Fa0/2 and Switch2 Fa0/2) have by default the same cost to the root bridge (19).
The  sender bridge ID has 2 parts: A configurable priority (Cisco default: 0x8000 / 32.768) and the MAC-Address. As the priority is the same on both switches, the MAC-Adress of Switch 1 wins because it is the lower one (last tie-breaker in this topology).
Changing the cost of the root-ports (Switch1 Fa0/1 "more expensive" or Switch2 Fa0/1 "cheaper") is the first possibility, changing the priority (Switch1 > 0x8000 or Switch2 < 0x8000) the second. John showed a very elegant way to achieve that on Switch2 with the spanning-tree root secondary macro.
I hope this helps, feel free to ask for more details
Rolf
hi,
i've checked in PT and the command is supported on a 2960. give it a try.
Chandu,
Btw: 0x8000 is hex, I used that because it's easier to learn than the decimal value of 32.768.
However, for the configuration you have to use the decimal values, so perhaps I confused you a little bit.
I thought you've changed the priority on switch3 to make it the root bridge, but you didn't, right?
In this case you could simply configure Switch 1 with a priority greater than 32.768 (decimal).
The root secondary macro is no option when you didn't run the root primay on Switch3 first.
Rolf
Chandu,
you're welcome! Thanks for the great feedback!
I started with LANs about 10 years ago and at this time I had no idea how all this stuff worked, so I know the value of  getting some help while starting to learn from my own experience at that time.
One little hint: When you start a new conversation and explain that you're learning and give some overview about your knowledge so far (regarding the topic), it's much easier to provide you with the adequate answer. This forum is really a great place to improve you knowledge and after some time you'll be able to give something back if you like to.
Best regards
Rolf
12 Replies 12
John Blakley
Chandu,
Can you post a diagram of how the switches are laid out?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
I guess the topology is a triangle and you want to influence which port becomes the designated port for the segment between the non-root bridges?
You can achive a change by
  • increasing/decreasing a root-port's cost on switch1/switch2
  • increasing/decreasing a bridge priority on switch1/switch2 when costs are equal
When costs and priorities are equal, the MAC-address (as part of the bridge ID) is the tie-breaker.
Rolf
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
You could change either STP port cost or STP port priority on your non-root switches.
chandra_rc16
Level 4
Level 4
I have attached the topology.
Chandu
Regards, Chandu
hi,
  • Lowest Sender-ID
Rolf
Hi Roff,
If i change the priority to > or < than 8000, what happens is either of the switches will become ROOT switch. I want only switch3 to be ROOT switch.
I hope this will work:
on Switch2.
Since i'm using PT i may not be able to do that i guess, because i never came across that parameter in PT.
Any way thanks for both of you.
Chandu
Regards, Chandu
hi,
Chandu,
Rolf
And. Yes i didn't changed the priority on switch3.
Regards, Chandu
chandra_rc16
Level 4
Level 4
Thanks Roff,
Really you're awsome.. for sure i'll try it.
And the way you imagined the topolgoy before i posted is simply superb.
How long are you into this field (Networking) ? I'm new here.
Chandu
Regards, Chandu
Chandu,
Best regards
Rolf
