Questions about 3750 stack
Hi All,
Could someone explain to me the following regarding 3750 switch stack technology
1. Will the master do all processing (i.e. routing, packets travels to ports of all member switch) or it will be distributed to all member switch in the stack?
2. If I have two member switch in a stack and currently in production, can I add two more without affecting the operation of these two member switch in production?
TIA
Re: Questions about 3750 stack
For a good overview of the behaviour of Catalyst switch stacks see "Understanding Switch Stacks" in Managing Switch Stacks at
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00801a6558.html
1. The master is responsible for a lot of the processing but not all of it.
2. You can safely add more units to the stack without effecting the operation of the stack.
(1)Yes its done my master.
(2)Sure you can.
JD
115
