Webcast-Catalyst9k
Questions about 3750G stack
I have 3750G switch.
I want to extend this switch to 3 3750G stack.
1. Do I have to reset the main switch that works?
2. I want that the switch that work will be the master.
I just need to execute the command ("switch priority 15" for master and 0 for other switches) or anything?
3. Can I do stack with ws-c3750g-48st-e and ws-3750g-48ts-s?
Thanks…
Everyone's tags (2)
Hall of Fame Super Gold
As long they are ALL running the same IOS and the same feature set.
No you don't.  Make sure that you power down your new stack members and install the stack cable first.  Then power up the stack member according to the order.
Super Bronze
Re: Questions about 3750G stack
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
BTW, my understanding is, you can mix feature sets (at least in the original 3750 series).  Stack election even takes this into account.  What you don't want to do is mix IOS versions.
VIP Super Bronze
373
