Questions about router config
Hi all,
Just wanted to get a little help here.  I am a bit green on routing and setting up routers.  I have never really had to do it in my career, but I find myself needing to re-educate myself.  With that, I have a Cisco 867VAE-K9 router.  I am connecting it to a cable modem set in bridge mode with static ip info from the ISP. To that router, I am connecting a AP1262N.  It will provide wireless to a building and eventually, as soon as I get the antenna up, public access Internet connection for a park.  I don't need a lot of security as far as prohibiting certain websites.  I am going to acheive this through openDNS.  So, with all of that, I was hoping someone could take a look at my current config and tell me what I am missing.  I know I am missing something...Thanks in advance for your help.  Also, if you see, the year is 1912, I can't for the life of me get it changed.  I am guessing that once I connect it to the provided modem, it will update with the correct year.....hopefully?
! Last configuration change at 09:31:36 gmt Fri Jan 26 1912
version 15.1
no service pad
hostname ParksRouter
boot-start-marker
boot-end-marker
enable secret 5 $1$vyTL$64bjmGFLqg/MLyex6SUIR1
no aaa new-model
wan mode ethernet
clock timezone gmt -6 0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.10.10.1 10.10.10.20
ip dhcp pool ParksPool
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
dns-server 68.113.206.10 24.217.0.5 <-- these are DNS given to me by ISP
domain-name duncanville.com
no ip domain lookup
ip domain name duncanville.com
ip name-server 68.113.206.10
ip name-server 24.217.0.5
controller VDSL 0
shutdown
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
description Internet Out - Charter
ip address x.x.x.x 255.255.255.252
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
no ip route-cache
duplex auto
speed auto
no cdp enable
interface Vlan1
description Internal LAN
ip address 10.10.10.1 255.255.255.0
no ip proxy-arp
ip nat inside
no ip route-cache
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet1
line con 0
exec-timeout 5 30
password
login
no modem enable
line aux 0
line vty 0 4
password
login
transport input all
scheduler allocate 60000 1000
end
Everyone's tags (1)
1 ACCEPTED SOLUTION
Tracy,
The config is incomplete, unless I am missing something where is the source list 1.
Tracy,
Edgar,
Thanks....you weren't missing anything....so, all I need at this point is to add a line in the config as follows
access-list 1 permit 10.10.10.0 0.0.0.255
Should that be followed by "any" to permit all traffic or is that implied in the statement iteself?
Tracy
Bronze
Is this router connected to a switch? If yes what interface is connected to the switch?
Eugen,
Thanks for the response, and no, it is not.  There will be a WAP attached providing WiFi service.  No need to call out a specific int on this device, they are all part of the default VLAN.
Purple
a standard ACL  like the one proided is enough:
But you should also do this on your interfaces:  ip route-cache cef
and change your static default route to point to next-hop ip instead of  outgoing interface
also if you want to communicate via name for router traffic you should reenable ip domain lookup.
Regards.
Alain
730
