01-27-2014 02:07 AM - edited 03-07-2019 05:48 PM
I'm learning etherchannels, so got the below doubts while practicing. Please help.
Here is my topology.
Here is the output of "show etherchannel" on Switch1 (Root switch)
Switch1#show etherchannel
Channel-group listing:
Group: 1
Group state = L2
Ports: 4 Maxports = 8
Port-channels: 1 Max Portchannels = 1
Protocol: PAGP
Group: 2
Group state = L2
Ports: 2 Maxports = 8
Port-channels: 1 Max Portchannels = 1 //What does this line mean? I really didn't understood this line.
Protocol: PAGP
Here is the output of "show etherchannel summary" on Switch1/Rootswitch
Switch1#show etherchannel sum
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 2
Number of aggregators: 2 // Is this the total number of channels on the switch?
Group Port-channel Protocol Ports
1 Po1(SU) PAgP Fa0/1(P) Fa0/2(P) Fa0/5(I) Fa0/6(I)
2 Po2(SU) PAgP Fa0/3(P) Fa0/4(P)
Here Fa0/5,Fa0/6 will also go to Switch3, here is the output of show etherchannel on swtich3
Switch3#show etherchannel
Group: 1
Group state = L2
Protocol: PAGP
Group: 2
Group state = L2
Protocol: PAGP
Here is the output of show etherchannel summary on switch3
Switch3#show etherchannel sum
d - default port
1 Po1(SD) PAgP Fa0/5(I) Fa0/6(I)
The output of show spanning-tree on both Switch1 & Switch3 doesn't show the Fa0/5,Fa0/6 as port channels, it is showing as individual ports, Why?
spanning-tree output from Switch3:
Switch3#show spanning-tree
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 32769
Address 0001.9713.EEAD
Cost 9
Port 25(Port-channel 2)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Address 00E0.F710.1331
Aging Time 20
Interface Role Sts Cost Prio.Nbr Type
Fa0/5 Altn BLK 19 128.5 P2p
Fa0/6 Altn BLK 19 128.6 P2p //Why these two ports are not showing up as a Portchannel?
Po2 Root FWD 9 128.25 Shr
spanning-tree output from Switch1:
Switch1#show spanning-tree
VLAN0001
This bridge is the root
Aging Time 20
Fa0/6 Desg FWD 19 128.6 P2p
Fa0/5 Desg FWD 19 128.5 P2p
Fa0/10 Desg FWD 19 128.10 P2p
Po1 Desg FWD 7 128.27 Shr
Po2 Desg FWD 9 128.28 Shr
Switch1#
Thanks a lot in advance.
Chandu
01-27-2014 02:31 AM
Can you post your config for all Etherchannel configurations for the etherchannel going to Switch3 from Switch2? Also, are these ports all the same speed?
01-27-2014 02:34 AM
I posted it already right, what do you want me to post from swtich1 ? Please tell me command.
Thanks in advance.
Chandu
01-27-2014 02:35 AM
The only etherchannel configured on Switch2 is for Switch1. There is no etherchannel from Switch2 directly connected to Switch3.
Chandu
01-27-2014 04:38 AM
Chandu,
Looks to me like you have the wrong ether channel group number int
switch 1 ports f0/5 & fas 0/6 they should be in group 2 not 1
try
int range fas0/5 - 6
channel-group 2 mode desirable
Alex.
Please rate useful posts.
01-27-2014 09:56 PM
Hi Alex,
On Switch3, i configured two channels for redundancy purpose, if 1st goes down, then second one should come up.
So, i should configure the same setup in Switch1, right? That's what i did.
On Switch1 the ports Fa0/1,Fa0/2 go to the etherchannel for Switch2.
Now i should replicate the etherchannel configuration of Switch3 on Swithc1 to have two Echannels b/w Sw1 and Sw3.
So on Switch1 i configured the Fa0/5,Fa0/6 ports to be in Po1 & the ports Fa0/3,Fa0/4 to be in Po2. But the spanning-tree output on Switch1 is showing the Fa0/5,Fa0/6 whereas it has to show only Fa0/10(PC),Po1,Po2.
VLAN0001
Aging Time 20
Fa0/5 Desg FWD 19 128.5 P2p // These two should be in Po1
Po1 Desg FWD 9 128.27 Shr
The output on SW3 shows below:
Why the channel is not forming?
Chandu
01-27-2014 05:55 AM
According to your info you on Sw1you have 1,2,5,6 as a port channel going to sw3 . On Sw 3 you have no port channels with 4 members in it (only shows 5 and 6 ) so you have a mismatch. You have something wrong on Sw3 either with the connections or the actual port channel config . Looks like 1,2 are not even in the port channel on Sw3 . Look at your config on Sw 1 and match it exactly on Sw 3 . SW3 should also show 1,2,5,6 in the port channel . On all use channel-group 1 mode desirable non-silent" , then shut and no shut the port channel.
01-27-2014 09:59 PM
No 3,4,5,6 go to SW3.
On Sw3 i configured two etherchannels with 2 members.
d - default port
Chandu
01-27-2014 10:03 PM
To bang on to point:
Can a Switch whose fours of its interfaces are aggreated into an etherchannel connect to two other switches, using two of its ports from the etherchannel to one switch and other two ports to another switch?
All the inputs are thankful.
Chandu
01-28-2014 08:53 PM
Please put your inputs, this is not yet resolved.
Chandu
01-28-2014 10:16 PM
Hi Chandra,
To answer your last question you can not have single etherchannel bundle connected from down stream switch to multiple upstream switches.
Multi chasis etherchannel (etherchannel from one downstream switch to multiple upstream switches) is supported in three cases
1) Nexus devices with vPC concept.
2) 6500 switches using VSS
3) 3750 switches with stack
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
01-29-2014 12:19 AM
Thank you.
And what does these two lines mean.
Chandu
01-29-2014 02:41 AM
Need inputs on the above quesstion
Thanks in advance.
Chandu
02-02-2014 05:59 AM
Hi Chandra,
Sorry for the delay in response. Note sure what you are seeing there is correct. I hope this output is from packet tracer. Ideally Max Port Channel should tell us what us the maximum number of port channel supported by that platform. If I remember it right this should have been displayed as 16 on a 2960. If you have a real switch you can check that on the same. Unfortunately I don't have access to any 2960.
For second question your assumption is correct.
Hope that helps.
Najaf
