Quick OSPF Q. about load bal
If 2 routes are advertised from different OSPF processes, would they still load balance the same as if they were part of the same process (assuming they are of equal weight)?
I can't see why they wouldn't but just need to double-check there's no weird preference rules.
Thanks!
J
1 ACCEPTED SOLUTION
Gold
Re: Quick OSPF Q. about load bal
We don't ever load share between two routing processes. One or the other process will win, and install its route in the local RIB, and the traffic will take that path.
In OSPF, the older route usually wins.
Russ
They should.I have not tried it practically but should work.
-amit singh
Gold
Russ
Thanks Russ, I wasnot sure about it.
It think its the same case with EIGRP as well.
-amit singh
Gold
We won't load share between two EIGRP processes, either, but the method used to choose which process wins is different between OSPF and EIGRP.
OSPF:
Lowest admin distance wins (Covers manually configured admin distances)
Oldest route wins
EIGRP:
Internals win over externals
Lowest metric wins
Lowest process ID wins
In other words, in EIGRP, if you have two identical routes learned in two processes, the process with the lower ID wins. The reason OSPF doesn't do this is that OSPF process ID's aren't significant, in the way EIGRP process IDs are.
Oh--had to edit to add this in.... There is a featurette request (defect) filed to allow OSPF processes to compare metrics and route types between processes. I don't know when it's going to be coded--but we did just get backing from a large customer for this functionality, so it might be pushed a little higher on the list.
Russ
That's great, many thanks guys for your help.
118
