quick static route question
my server folks want their ftp server
to use a specific route...this is the only device they want to use this path
if the ftp server on the far end is
192.168.5.6 255.255.255.0
would my static route be
192.168.5.6 255.255.255.255 192.168.4.3
If 4.3 is the path to be taken.
i would use all 255 subnet for this
particular route to this particular device...correct?
Hall of Fame Super Blue
Re: quick static route question
It's not entirely clear where you are applying the route ? is it on a server or on a router.
means to get to host 192.168.5.6 send the packet to 192.168.4.3. Yes you would 255.255.255.255 if you just want to specify a destination host.
Jon
yes..the route is for one specific host...
the configuration entry would be on the router,,
so all 255's?
it looks like it is routing the entire subnet
instead of one device
i only want one device to use this route
Router#sh ip route 192.168.9.0
Routing entry for 192.168.9.0/32, 1 known subnets
Redistributing via eigrp 1
S 192.168.9.80 [1/0] via 192.168.21.236
Yes all 255's which specifies it is a host entry rather than a subnet entry.
Jon
You need to use a route map that will match the source(ftp server) and set ip next hop (new ip)
194
