Quick VLAN Question.
nelson.garcia
I've noticed in my L2 2960 Cisco switch that you can configure a VLAN by typingg in (from global config mode):
vlan #
or
int vlan #
My question is, why is there these two options?
I can assign a name to my VLAN when i type in
vlan 20
name (name)
but not when I go
interface vlan 20
name (name)
unrecognized command.
So my question is, what's the difference between the two?
Thanks a lot =)
Nelson
Apologies, should have been more specific :-).
Where i said
"The 2960 is a L2 switch only so you can only create 1 L3 vlan interface and this interface is used so you can remotely connect to the switch."
i should have said that you can create more than 1 L3 vlan interface but only one can be active ie up/up at one time.
Jon
Jon Marshall
Nelson
They are not the same thing.
1) vlan in global config mode creates the vlan at layer 2. You can create multiple vlans at layer 2 on the 2960 switch and you can then allocate ports into these vlans.
2) int vlan 20
this does not create a L2 vlan. It creates a L3 vlan interface or SVI (Switched Virtual Interface). To route between vlans you need L3 vlan interfaces. The 2960 is a L2 switch only so you can only create 1 L3 vlan interface and this interface is used so you can remotely connect to the switch.
A L3 switch such as the 3560/3750/4500/6500 can have multiple L3 vlan interfaces.
So L2 switch can have multiple L2 vlans + 1 L3 vlan interface.
L3 switch can have multiple L2 vlans + multiple L3 vlan interfaces.
Jon
Thank you for the informative and quick reply Jon.
Nelson
Just a quick followup Jon. While I don't deny that your answer was correct. I tested out what you said about L2 switches only allowing 1 L3 VLAN interface.
I went into global config mode and created
int vlan 20
ip address # subnet #
and
int vlan 30
I then (from privileged exec mode) typed
sh ip int bri
and both interface vlan 20 and interface vlan 30 showed up on the list, albeit down.
Is this supposed to happen?
Nelson
Jon
