"no keepalive" not working on 6506-E/IOS 15.1 adventerprise/routed port
Hi all,
just want to understand why the "no keepalive" doesn´t work...i always used it to get a port UP/UP on a router or a switch when having to set up a management-system for example, which autochecks all ports if they are UP.
Actually i´m confronted with the behaviour that exactly this trick won´t work for me...because i have to set up loads of actually not connected ports on this switch.
Gets quite tricky and time consuming if i cannot use the "no keepalive" for setting up monitoring on these ports. And for sure i will remove this again after my PRTG configuration.
Has anyone an idea why this isn´t working on this exact device? I tried on L2-ports also, they immediately go to DOWN7DOWN, no matter if i issue an "shut"/"no shut"...
Confused.
Thanks and many thanks for the tips in advance,
Andreas
Everyone's tags (4)
...and btw its exactly the same on the other switch, a similar model with the same configuration...
Portconfig of such a port:
interface GigabitEthernet2/24
description ----
ip address 1.2.3.2 255.255.255.0
standby 253 ip 1.2.3.1
standby 253 priority 255
standby 253 preempt
logging event link-status
load-interval 30
no keepalive
end
GigabitEthernet2/24 is down, line protocol is down (notconnect)
  Hardware is C6k 1000Mb 802.3, address is c067.afda.4300 (bia c067.afda.4300)
  Description: ---
  Internet address is 1.2.3.2/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 0/255, rxload 0/255
  Keepalive not set
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseT
  input flow-control is off, output flow-control is desired
  Clock mode is auto
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
  L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
  L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
  L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
Hi Andres,
I have testet it on Catalyst 3850 w/ IOS 03.02.02.SE w/ the same result as yours.
The interface stays "notconnectet" no matter if I use "no keepalive" or not...
In the past it worked only on L3-ports in a router, not on dual-ports (L2 or L3) like in Catalyst 6500... or?
Greets
./chris
i did it (if i remind correctly) everytime on routers before...so i´m not quite sure if this would be perhaps the reason...hmmmm
actually i have no 3750 (for example) accessible in reach, where i could test if there would be the same behaviour
perhaps one of the cisco guys themselves could shed some light on this?
...wasnt able to find documentation regarding this by now...
but thanks for your input, chris
In the meantime I have tested w/ Catalyst 3750G and IOS 15.0(2)SE!
Here the result:
GigaPower#sh ver | i Version
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 15.0(2)SE1, RELEASE SOFTWARE (fc1)
GigaPower(config-if)#do sh run int g1/0/1
Building configuration...
Current configuration : 275 bytes
interface GigabitEthernet1/0/1
description *** not in use ***
no switchport
ip address 192.168.13.1 255.255.255.0
no logging event link-status
storm-control broadcast level pps 50
storm-control multicast level pps 50
storm-control action shutdown
no keepalive
end
GigaPower#sh int g1/0/1
GigabitEthernet1/0/1 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 001a.e2ac.9142 (bia 001a.e2ac.9142)
  Description: *** not in use ***
  Internet address is 192.168.13.1/24
  MTU 9000 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Keepalive not set
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
GigaPower#
Same behavior like on Catalyst 3850...
regards
./chris
Re: "no keepalive" not working on 6506-E/IOS 15.1 adventerprise/
ok, thanks chris
so it is perhaps related to the dual functionality of this port on a switch.
crap...seems i really have to connect each of the ports then...
task for next monday then :(
492
