Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
"%PLATFORM_RPC-3-MSG_THROTTLED" in log
there are a lot of messages in log like this:
%PLATFORM_RPC-3-MSG_THROTTLED: RPC Msg Dropped by throttle mechanism: type 3, class 21, max_msg 8, total throttled 1355
-Traceback= 5FFCA4 43876C 4388B4 4392EC 439510 1E25F0
And the CPU utilization turns to 47% from 6%. There is no flow in all ports except vlan1.
#sh proc cpu | e 0.00
CPU utilization for five seconds: 43%/8%; one minute: 47%; five minutes: 47%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
5 650327593594269354 18 7.52% 6.10% 7.27% 0 Pool Manager
30 1718957 264721815 6 0.16% 0.07% 0.03% 0 Fifo Error Detec
68 7002122028202361 0 0.16% 0.17% 0.16% 0 Hulc LED Process
104 73389293 509261581 144 22.22% 25.51% 25.96% 0 IP Input
Re: "%PLATFORM_RPC-3-MSG_THROTTLED" in log
Please check the link below.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_35_se2/release/notes/OL9778.html
Seems like there are too many ARP requests generated out of the some port which has security feature like NAC enabled on it.
Could you tell me how to confirm it ?
And I have checked that there is no snmp-server ifindex persist configured.
Thank you very much!
Can you post the configuration of the switch? specifically the switch port configuration.
version 12.1
no service pad
service tcp-keepalives-in
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
logging buffered 40960 debugging
clock timezone CST 8
ip subnet-zero
no ip source-route
ip routing
no ip domain-lookup
vtp domain ***
vtp mode transparent
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
spanning-tree vlan 1 priority 8192
vlan 100
interface Port-channel1
switchport trunk allowed vlan 1
switchport mode trunk
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/19
no switchport
ip address *****
load-interval 30
interface GigabitEthernet1/0/20
interface GigabitEthernet2/0/24
load-interval 60
interface GigabitEthernet2/0/25
interface GigabitEthernet3/0/22
channel-group 1 mode on
interface GigabitEthernet3/0/23
interface GigabitEthernet3/0/24
switchport access vlan 100
switchport mode access
load-interval 30
duplex full
speed 100
interface GigabitEthernet3/0/25
interface GigabitEthernet3/0/26
interface GigabitEthernet3/0/27
interface GigabitEthernet3/0/28
load-interval 30
interface GigabitEthernet4/0/1
load-interval 30
speed 100
interface GigabitEthernet4/0/2
interface GigabitEthernet4/0/11
spanning-tree portfast
interface GigabitEthernet4/0/12
interface GigabitEthernet4/0/13
interface GigabitEthernet4/0/14
interface GigabitEthernet4/0/28
interface Vlan1
ip address *** 255.255.255.0
no ip redirects
standby 13 ip **
standby 13 timers 1 3
standby 13 priority 150
standby 13 preempt
interface Vlan100
ip address *** 255.255.255.240
no ip redirects
router eigrp **
network **.0.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 *****
no ip http server
logging ***
snmp-server enable traps snmp authentication warmstart linkdown linkup coldstart
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps flash insertion removal
snmp-server enable traps bridge
snmp-server enable traps stpx
snmp-server enable traps rtr
snmp-server enable traps port-security
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps MAC-Notification
snmp-server enable traps envmon fan shutdown supply temperature
snmp-server enable traps hsrp
snmp-server enable traps cluster
snmp-server enable traps copy-config
snmp-server enable traps syslog
snmp-server enable traps bgp
snmp-server enable traps vlan-membership
line con 0
line vty 0 4
login local
line vty 5 15
exec-timeout 30 0
no login
ntp clock-period 36028679
ntp server ***
ntp server ***
ntp server ***
monitor session 1 source vlan 100
monitor session 1 destination interface Gi3/0/1
end
there are a few multicasts in 3 ports and only the 3 ports are configured IP address.
http://www.cisco.com/en/US/customer/docs/switches/lan/catalyst3550/software/release/12.1_19_ea1/configuration/guide/swuncli.html#wp1012800
The above link contains the unsupported commands in 3750. Can you please try removing the commands listed.
I cannot access the link, "Forbidden File or Application" is appeared.
any else could I do ?
Please find the related list below.
Unsupported User EXEC Commands
ifindex
private-vlan
Unsupported Global Configuration Commands
spanning-tree etherchannel guard misconfig
snmp-server enable informs
snmp-server enable traps flash removal
Unsupported Interface Configuration Commands
ip accounting
ip load-sharing [per-packet]
ip mtu bytes
ip route-cache
ip verify
ip unnumbered type number
All ip security commands
ip accounting-list ip-address wildcard
ip accounting-transits count
ip cef accounting [per-prefix] [non-recursive]
ip cef traffic-statistics [load-interval seconds] [update-rate seconds]]
ip flow-aggregation
ip flow-cache
ip flow-export
ip gratituitous-arps
ip local
ip reflexive-list
router egp
router-isis
router iso-igrp
router mobile
router odr
router static
frame-relay ip rtp header-compression [active | passive]
frame-relay map ip ip-address dlci [broadcast] compress
frame-relay map ip ip-address dlci rtp header-compression [active | passive]
ip igmp helper-address ip-address
ip multicast helper-map {group-address | broadcast} {broadcast-address | multicast-address} extended-access-list-number
ip multicast rate-limit {in | out} [video | whiteboard] [group-list access-list] [source-list access-list] kbps
ip multicast use-functional
ip pim minimum-vc-rate pps
ip pim multipoint-signalling
ip pim nbma-mode
ip pim vc-count number
ip rtp compression-connections number
ip rtp header-compression [passive]
ip pim accept-rp {address | auto-rp} [group-access-list-number]
ip pim message-interval seconds
There is no unsupported commands in my switch.
And I find a strange thing about flow. There are 2 vlans in switch, the input rate of vlan1 is 13Mb/sec and the output rate of vlan2 is 12Mb/sec. There is no flow in other ports both input and output. Why would be this ?
910
