"show cdp nei detail" shows a wrong IP address (10.1.1.1)
AYTOIAM2009
I have a C4500 connected to a C6500 (the connection is though two switchports TengigabitEthernet (10GBSR))
When I run "show cdp nei detail" in the C4500, I got an IP 10.1.1.1 for the C6500, but this device has not that IP address.
When I run the command in the C6500, I got the right IP address for the C4500.
The "show version" for both devices is:
For the C6500:
IOS (tm) s72033_rp Software (s72033_rp-ENTSERVICESK9_WAN-M), Version 12.2(18)SXF6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Mon 18-Sep-06 23:23 by tinhuang
Image text-base: 0x40101040, data-base: 0x42D90000
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-ENTSERVICESK9_WAN-M), Version 12.2(18)SXF6, RELEASE SOFTWARE (fc1)
cisco WS-C6506-E (R7000) processor (revision 1.1) with 458720K/65536K bytes of memory.
Processor board ID SAL104897GQ
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
1 Virtual Ethernet/IEEE 802.3 interface
50 Gigabit Ethernet/IEEE 802.3 interfaces
4 Ten Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
For the C4500:
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-ENTSERVICESK9-M), Version 12.2(31)SGA, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 08-Sep-06 10:13 by ccai
Image text-base: 0x10000000, data-base: 0x118F6934
ROM: 12.2(31r)SGA
Pod Revision 14, Force Revision 34, Tie Revision 32
cisco WS-C4507R (MPC8540) processor (revision 11) with 524288K bytes of memory.
Processor board ID FOX103901JS
MPC8540 CPU at 800Mhz, Supervisor V-10GE
Last reset from PowerUp
3 Virtual Ethernet interfaces
100 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Any idea about what's the problem?
Thanks very much.
Did you confirm that there is no IP configure with any interface? otherwise just confirm it by using "show IP interface brief" command
6 Replies 6
jimmysands73_2
Level 5
Level 5
Just curious, not related, but why is the config register set to :
  • Boots into bootstrap
  • Ignores break
  • Boots into ROM if initial boot fails
  • 9600 console baud rate
Reza Sharifi
Can you post "sh cdp nei det" from both devices?
These are the outputs for the command in both devices:
.- For the C4500:
C4K5-TVT-02#sho cdp nei det
Device ID: C6K5-IAMTVT-02
Entry address(es):
  IP address: 10.1.1.1
Platform: cisco WS-C6506-E,  Capabilities: Router Switch IGMP
Interface: TenGigabitEthernet1/1,  Port ID (outgoing port): TenGigabitEthernet4/1
Holdtime : 123 sec
Version :
advertisement version: 2
VTP Management Domain: ''
Native VLAN: 1
Duplex: full
Management address(es):
Unidirectional Mode: off
.- For the C6500:
C6K5-IAMTVT-02>sho cdp nei det
Device ID: C4K5-TVT-02
Entry address(es):
  IP address: 10.99.193.12
Platform: cisco WS-C4507R,  Capabilities: Switch IGMP
Interface: TenGigabitEthernet4/1,  Port ID (outgoing port): TenGigabitEthernet1/1
Holdtime : 176 sec
Version :
VTP Management Domain: 'DOMTVT'
Native VLAN: 1
Duplex: full
¡¡ You were right !!
We have that IP address configured with an interface that is down:
C6K5-IAMTVT-02#sho ip interface brief
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet5/2         10.1.1.1        YES NVRAM  down                  down
Thank you very much.
Kind Regards.
Can you clear "cdp" entries on 4500 switch and check
"clear cdp table"
Sri
