"Spanning-tree port type" option between 7K and 5K
Robert Cuello
I have a port-channel with vpc from a pair of 7K to a pair of 5K and from the 5K to the 7K. I need to know the Cisco recommended "spanning-tree port type" for this link. By default it uses the "port type normal" but I need to know if this is the recommended configuration. Thanks
Rajeev Sharma
Hey Roberto,
VPC eliminates the use of STP so i believe you should be good. Check the guide:
http://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
HTH.
RS.
