"Storm-Control action shutdown" on 6500 VSS
DanielKerman
Hello everyone!
I know this might be a silly question, but im somehow unable to configure "Storm-control action shutdown" on a 6500 VSS running 12.2(17r)SX7.
I found that the command exists in the command referance of IOS 12.2SX but when I try to issue the command on the machine I get:
6500-VSS(config-if)#storm-control ?
  broadcast  Broadcast address storm control
  multicast  Multicast address storm control
  unicast    Unicast address storm control
Whether I try to configure it on the port-channel or on its members the result is the same.
What am I missing?
Reza Sharifi
What type module are you using?  Some modules don't support storm control.
have a look:
Configuration Guidelines and Restrictions
When configuring traffic storm control, follow these guidelines and restrictions:
FlexWAN Fast Ethernet port adapters and all WAN modules supporting Ethernet SPAs do not support traffic storm control.
The following LAN switching modules do not support traffic storm control:
WS-X6148E-GE-45AT
WS-X6148A-GE-45AF
WS-X6148A-GE-TX
WS-X6148-GE-45AF
WS-X6148-GE-TX
WS-X6148V-GE-TX
WS-X6548-GE-45AF
WS-X6548-GE-TX
WS-X6548V-GE-TX
Link for more info:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/storm.html#wp1039559
Hello Reza, and thank you for your reply.
I came across this documen before, we do not have any of the unsupported modules.
The thins is that storm control is enabled on the machine on few port-channels, but when i try to issue the
"Storm-control action shutdown" i get nothing. Its the same result when I try to configure it on the port-channel or on its physical interface:
