QWEST DSL and the 877
Does anyone have any success stories with using the 877 wireless ADSL router with QWEST DSL? I have given up on QWEST's solutions because I want to do a LAN to LAN VPN between two offices without leasing multiple static IPs from QWEST.
Is this doable or am I setting myself up for another long weekend?
Thanks for any input, positive or not...
1 REPLY
Re: QWEST DSL and the 877
Hi Hortigo
You at least should have a static ip at one end so that you can have the ipsec vpn tunnels created between them.
If you are able to get static ips on both the end then you can have static ipsec tunnels being created through which you can have the data transfer between the locations..
do refer this config sample which can help you out in getting started ...
http://www.cisco.com/en/US/tech/tk583/tk372/tech_configuration_examples_list.html
you can locate a suitable config sample under "IPSec on Router to Router" topic...
regds
148
