Radius authentication for privileged access
          I have configured Cisco 6513 for radius authentication with following commands.
aaa new-model
aaa authentication login authradius group radius line
aaa accounting exec acctradius start-stop group radius
radius-server host <radius-ip> auth-port 1812 acct-port 1646 key 6912911
line vty 0 4
login authentication authradius
     This is working pretty fine. I want to configure radius authentication for priviledged access / for enable access.
     I am using TeKRadius as Radius server.
     Please help.
Thanks and Regards,
Pratik
Everyone's tags (3)
Bronze
Re: Radius authentication for privileged access
Hi Pratik,
Try adding:
aaa authentication enable default group radius enable
Nick
Hi Nick,
          I tried that but its not working....
          It asks username password during login and then when I enter enable it asks for simply password, and any of the password will not work, not even the enable password or the radius password. Then i have to shutdown the radius server service to get the privileged access of the switch.
Pratik
Bronze
Hi Pratik
Sorry I mostly use only TACACS+ for AAA as it provides better granularity of access controls.
You'll need to make some specific changes to your RADIUS config so that nominated users ( the ones you want to be able to go to enable mode ) get put straight into enable mode upon login.
There's a guide here http://www.blindhog.net/cisco-aaa-login-authentication-with-radius-ms-ias/ which details the steps if you're using the Microsoft IAS radius server - you should be able to figure out that changes you need to make to your own server from there.
Nick
Message was edited by: NickNac79 - Spelt the OP's name wrong, sorry.
Please see http://forums
1052
