RADIUS Config
I am looking to deploy a simple RADIUS solution and I'm having some issues.  I would like to have RADIUS authentication for selected Active Directory users.  Should the RADIUS server become unavailable, I would like to be able to log in to the switch using the switch local admin account. This is not working with my current configuration.
My users:
User 1: testuser
User 2: admin (local switch admin)
User 1 can authenticate to the switch via RADIUS and cannot authenticate to the locally (as I have not included User 1 in the local db on purpose).
User 2 cannot authenticate using RADIUS as expected however cannot log on to the switch locally either which is expected.  This is not working properly.
My configuration:
username admin privilege 15 secret Password1
aaa new-model
aaa group server radius IAS
 server 192.168.193.162 auth-port 1812 acct-port 1813
aaa authentication login userAuthentication group radius local enable
aaa authorization config-commands
aaa authorization exec userAuthorisation group IAS group radius local
aaa session-id common
line con 0
 logging synchronous
line vty 0 4
 login authentication userAuthentication
line vty 5 15
Can anyone see what I'm doing wrong?
Thanks in advance :D
SteveP
1 ACCEPTED SOLUTION
Steve,In your current setup,
Steve,
In your current setup, I think you're going to have a problem. If the radius server is up at all, it will just send a reject back to the router should it either not find a user or the user have the incorrect password. The only way the router will failover to the local database is if the radius server isn't available at all.
You can set the local database first in aaa and then configure the radius server. The admin user will be able to log in using the local database, but the user will not be able to since they're not in there. If the user simply wasn't found in the local database, you would roll over to the radius server and authenticate there.
Soooo, try to flip your command from:
to:
aaa authentication login userAuthentication local group radius enable
HTH,
John
HTH, John *** Please rate all useful posts ***
Steve,
to:
HTH,
John
Hi JohnThat worked a treat.
Hi John
That worked a treat.  Thank you very much.
Cheers
SteveP :D
130
