Webcast-Catalyst9k
radius config
I am trying to set up Radius on a cat4506 with IOS version 12.2 but none of the radius-sever commands work. There isn't anything about radius when using the "?" in config mode. Any ideas?
1 ACCEPTED SOLUTION
Re: radius config
You need to enable aaa by entering the command:
aaa new model
After that the aaa authorization, authentication and accounting commands should be available as well as the radius-server commands.
Andy
Re: radius config
aaa new model
Andy
Re: radius config
see below for full radius config. the config will also fallback to local authentication if your radius server is down.
aaa new-model
radius-server host (your radius server ip) auth-port 1812 acct-port 1813
radius-server key (your radius secret key
radius-server source-ports 1645-1646
username **** password ******
aaa authentication login default group radius local
aaa authentication login console local
Franco
Please rate if this helps.
147
