RADIUS Server for Cisco 2950
i have set up a RADIUS server(freeradius) in linux,now you i tell my switch to authentication via radius server? i mean the user name & password will be on the radius server. switch should prompt for user name & password so that it will get the info from the radius server, what are the commands should i specify in the cisco 2950?
Silver
Re: RADIUS Server for Cisco 2950
thankz for ur reply,
i am bit confussed about the radius setup in the switch, is that configuration below mentioned will be sufficient for a very simply authenctication?
radius-server host 10.1.1.1 nonstandard
radius-server key
my requirement, username & password will be set on the radius server, all the switches should log in with the username & password mentioned on the radius server,
Silver
Hi, you'll need to specify an AAA group and then the aaa external server (the radius)
You can see:
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a0080093c81.shtml
Take a general look to the document and specially to your case, Login authentication:
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a0080093c81.shtml#login_auth
Hope this helps you.
Pls, rate the post if useful.
859
