rate-limit command in CAT3750
mkamar
I wonder, why rate limit command is not functioning under routing enable gig interfaces in CAT3750 , I don't thing it's a SDM issue, Do you have idea why it's not functioning, Note.: I mean by not functioing that the command is accepted under the interface But the conform and exceed counters not incremeting and acordingly no action have been taken, thanks
szahid
Level 3
Level 3
because it is an unsupported command
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12240se/scg1/swuncli.htm
Use "srr-queue bandwidth limit" comamnd instead to limit the egress bandwidth.
