Rate limit VLAN on Cisco 3560
Hello
I`m trying to rate limit some specific traffic passing through a 3560 switch on some VLANs.
What I have done is create an access list:
access-list 101 permit icmp any any echo
access-list 101 permit icmp any any echo-reply
Then I set a rate limit on the VLAN interface:
rate-limit input access-group 101 128000 8000 8000 conform-action transmit exceed-action drop
rate-limit output access-group 101 128000 8000 8000 conform-action transmit exceed-action drop
CEF is enabled.
But this does not rate limit the traffic like it should, what am I missing here?
Super Bronze
Re: Rate limit VLAN on Cisco 3560
From latest 3560 configuration guide:
Unsupported Interface Configuration Commands
rate-limit
You might want to consult configuration guide QoS chapter's section on "Policing on SVIs", e.g. http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_50_se/configuration/guide/swqos.html#wp1766801, for your IOS.
I recall having same issues on this platform. I used following workaround:
1-I know 3560 can police inbound, so I used a service policy on physical port. referring to a class map & ACLs.
2-for outbound, I used the upstream port ad policed its traffic inbound.
Sam
Thank you for quick reply.
I have done some VLAN filter, bot nothing like in the linked article.
How would I do this config for desired results?
Super Bronze
I am a little fuzzy but I believe you have to turn on "mls qos" have you done this?
1872
