Rate limiting at vlan interface on Cat6509
tdennehy
I would like to rate limit the users on vlan 2099 - it is for guest users.  I have already put a filter on that vlan to limit the protocols and it works fine.  The rate-limiting does not work at all. Can someone tell if I am missing something? vlan access-map Filter_Guest 10 match ip address Guest_WLAN_Restriction action forward ! vlan filter Filter_Guest vlan-list 2099 ip access-list extended Guest_WLAN_Restriction permit udp any any eq bootps permit udp any any eq bootpc permit udp any any eq domain permit tcp any any eq domain permit udp any any eq 80 permit tcp any any eq www permit tcp any any eq 443 deny  ip any any interface Vlan2099 description = Dilbert_Development ip address 10.128.254.254 255.255.255.0 ip helper-address 123.123.133.1 ip helper-address 123.123.32.1 rate-limit input access-group 175 64000 8000 8000 conform-action transmit exceed-action drop rate-limit output access-group 175 64000 8000 8000 conform-action transmit exceed-action drop
27 Replies 27
Lei Tian
CAR is the legacy way of doing rate limiting; have you try policy-map and policing instead?
HTH,
Lei Tian
I did try a policy-map and policing and it did not work. I believe I had it misconfigured since I read something last night that leads me to that conclusion.
allan.thomas
Level 8
Level 8
The only aspect from your description that I see has no correlation to what you are attempting to limit is the access-group 175.  Under the rate-limit command you specify the match criteria as a specific access-group, do you have the ip access-list 175 configured as it does not appear within the information you have provided?
Allan.
Allen,
I forgot to put that in the question.  The ACL is as follows:
access-list 175 permit ip any any
I must be missing something... because it just isn't working!
Tim
I found this statement on this webpage:
"In order to enable CAR, you must enable Cisco Express Forwarding (CEF) on the box. In addition, you must configure a CEF-switched interface for CAR"
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a00800fb50a.shtml
I want to enable it on an VLAN, since the machines are downstream and not directly connected to this 6509. The VLAN interface is on the 6509.
Jim Coyne
ip access-list extended RATELIMIT
permit ip any any
class-map RATELIMIT
match access group RATELIMIT
policy-map RATELIMIT
class RATELIMIT
  police 64000 8000 8000 conform-action transmit exceed-action drop
int Vlan 2099
service-policy output RATELIMIT
service-policy input RATELIMIT
Jim,
I tried that already. My policy is identical to yours, but I plugged yours in just in case I mistyped something. Your policy doesn't work either. I must be missing some other global command is all I can think.
Here's what I have below. I have a laptop on my desk on that vlan, IP is 10.128.254.152, and can hit the speed test site on the internet and has unrestricted downloads and uploads.
mls qos
class-map match-all identify_Guest_WLAN_Ratelimit
match access-group name Guest_WLAN_Ratelimit
class-map match-all RATELIMIT
match access-group name RATELIMIT
policy-map police-WLAN-Guest-traffic
class identify_Guest_WLAN_Ratelimit
police cir 64000 bc 8000 be 8000 conform-action transmit exceed-action drop violate-action drop
class RATELIMIT
interface Vlan2099
ip access-list extended Guest_WLAN_Ratelimit
permit ip any any
permit ip any any
Tim
What's the output of sh policy-map interface vlan 2099?
CSFC6503#sh policy-map interface vlan 2099
Vlan2099
Service-policy input: RATELIMIT
class-map: RATELIMIT (match-all)
Match: access-group name RATELIMIT
police :
64000 bps 8000 limit 8000 extended limit
Earl in slot 5 :
0 bytes
5 minute offered rate 0 bps
aggregate-forwarded 0 bytes action: transmit
exceeded 0 bytes action: drop
aggregate-forward 0 bps exceed 0 bps
Class-map: class-default (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
Service-policy output: RATELIMIT
police :
Earl in slot 5 :
5190 bytes
aggregate-forwarded 5190 bytes action: transmit
0 packets, 0 bytes
Match: any
Hi Tim,
I suspect that object criteria is falling into the class-default which is specifically for traffic that is not specifically classified.  As you have all one class which consist of essentially everything could you try configuring the policy-map as follows so that you only have the class class-default within it, and then try testing again:-
  class class-default
interface Vlan2099
Could you post the show policy-map, and show interface policy-map command.
Allan.
Allen,
Here is what the config looks like now:
class class-default
permit ip any any
interface Vlan2099
CSFC6503#sho policy-map
Policy Map police-WLAN-Guest-traffic
Class identify_Guest_WLAN_Ratelimit
Policy Map RATELIMIT
Class class-default
Vlan2099
class-map: class-default (match-any)
Match: any
police :
Earl in slot 5 :
0 bytes
Match: any
police :
Earl in slot 5 :
602 bytes
aggregate-forwarded 602 bytes action: transmit
CSFC6503#
Hi Tim,
From the show policy-map interface vlan2099, the outbound service-policy appears to have bytes matched.  To specifically test whether the policed cir is working you could revise the policy so that the conform action is set to drop, this will ensure that any traffic matched which conforms within the CIR is dropped directly.
This would prove that the policy is working as desired and that the your testing is not exceeding the CIR.  I would also configure the access-list to be more explicit and configure it so initially only your testing IP host is configured to any, and any to your IP host.  The example I provided in my previous post simply negates the requirement to have a separate access-list to match-on as the class class-default provides the same catch-all.
Allan.
Allan,
I have another box that I use for testing, and I applied the config to it and it works. The main difference is the machine I'm hitting the bandwidth server is on copper, plugged into a copper port on the 6509.
The box that isn't working is a user that enters the box through a vlan trunk. What are the odds that traffic entering through a trunk isn't supported?
I'm going to go prove my theory in a few minutes.
Tim
Hi Tim,
That shouldn't be a problem, if that is the case, then I assume that you have not configured the physical trunk interface on the 6500 for vlan based QoS?  If you haven't could add this command 'mls qos vlan-based' to the appropriate interface and try your tests again?
Allan.
